1 - 8 of 8 Posts
1st Gen 2.4
Replacing the radiator on my 2001, 5 lug 2.4L. Didn’t notice this before but the fan blades look really close to the power steering pump pulley and the tensioner pulley for the p/s pump. Anyone else have pictures of theirs, or can confirm this is how it’s supposed to be?
Automotive tire Hood Automotive lighting Tire Motor vehicle
Hood Bumper Automotive exterior Auto part Metal
Is it possible that you installed the fan on the wrong side of the clutch? Since you did work on that last, I'd look at that first. The shroud is very easy to get off and take a pic or something.
  • Like
Reactions: makotako
1st Gen 2.4
Discussion Starter · #5 ·
Is there a good way to pull the shroud without disconnecting the upper radiator hose? I've refilled my coolant multiple times within the past couple of weeks already I'm trying to avoid spilling some more. I'll have a look tomorrow I did not consider that. Thanks
Yes. The bottom portion of the shroud that extends rearward towards the fan snaps off with two little clips. Pull that off first, then take the bolts that hold the shroud off and you should be able to manipulate it out of there. It's a bit of a pain, but it can be done.
Another option is to unbolt the fan and let it fall into the shroud. Then remove everything together.
  • Like
Reactions: makotako
1 - 8 of 8 Posts
