1 - 11 of 11 Posts
Babylon is Falling
Came off a 2004 TRD X-Tra Cab that had play in the steering column. edit: Dude replaced the column and ended up with an extra Combination Switch Assembly. I got it for its intermittent wiper switch. I put my working, non-intermittent wiper switch back on it to make it complete. I tested and verified the light switch works perfectly fine.
I dont know for sure, but I believe it'll also fit and work on '98-up Tacos.
The entire assembly: $50
Will sell items separately:
- Light Switch $20
- Non-Intermittent Wiper Switch $20
- SRS Spiral Cable $20
Locals preferred.
Babylon is Falling
Discussion Starter #2
bumpola
Babylon is Falling
Not 100% positive on this, but they may also work on '98-'00 Tacos too.
Babylon is Falling
Discussion Starter #4
Rheostat is gone. Thanks mitzu! :waytogo:
Babylon is Falling
Discussion Starter #7
Babylon is Falling
Discussion Starter #9
SRS Spiral Cable is SOLD. Thanks xxpl0sive1! :waytogo:
Pussay!
thanks!!! very fast shipping
a little fyi for anyone else. the spiral cable worked on my 99 prerunner just fine, however, the harness that connects to the actual airbag is different. i had to switch out the harness from the old one to the new one. other than that, it bolted right up.
Babylon is Falling
Discussion Starter #11
Cool Federico, thanks for the update. Glad it worked out for you. :waytogo:
1 - 11 of 11 Posts
