1 - 2 of 2 Posts
I have a 1998 4x4 manual 2.7 tacoma 250k miles. Shop said #1 cyIinder was dead. We recently aquired a 2003 2.4 2wd donor. So in just looking at the basics, the 03 has coil per cylinder which 98 doesn't have. Most of the hookups are similar... but the computer plugs are completely different. I tried to research b4 purchasing donor. Most threads said it was a pretty direct swap. Any help is appreciated, and any shops near 75455 can earn this work if interested
(1) Welcome to CT!
(2) What exactly was 'dead' about the #1 cylinder in the 3RZ (2.7)?
(3) Are you looking to swap entire engines, or are you thinking of mixing 'n matching heads / blocks?
(4) What transmission was used on the '03 2WD donor? Are you aware there can be an issue with bell housings when swapping 2RZs / 3RZs?
  • Like
Reactions: pimpRunner
1 - 2 of 2 Posts
