For a 2WD 2.4L Four-Cylinder Tacoma:
Is or are there any better options for the cheap/broken plastic bottom tray? Mine is almost split in half...
I did a search & found these part numbers for OE Toyota parts-
Tray 74431-03010
Tie-Down Bar 74404-35140
Long "J-Hook" Clamp 74451-04040
Long story short, The simple plastic tray is $40 alone! Is there something better out there? Any upgrade kits?
At least the tie-down bar is $20 w/ free shipping on eBay...
I found a custom-tacos listing for a bracket assembly for an Optima Battery but the OP hasn't visited since 2017 & their original post was back in 2009...
www.customtacos.com
Tray 74431-03010
Optima battery spacer / tray....by STREETACOS
This allows you to get rid of the old acid dripper and run a Optima battery in the 95.5-04 Tacoma. It works with the OEM hold down clamp and will keep the battery from moving around under hard driving thanks to it's 4 side tabs, dowel pin and set screw tab. Available in silver or black finish...
