1 - 15 of 15 Posts
Hi everyone,does anybody here know if the X is belt driven or chain driven?I've been hearing different stories.:confused:
Re: Timing belt or timing chain?
chain
Thank for reply,but I went to dealer today,the "MASTER" technician told me the X is belt drive,he said he is DAMN sure!
Nope..its Chain
Gadget has confirmed it as well..They are Master Morons sometimes..One time I took my XR there and a Tech was like OHHH does that got the 3.4 S/C on it
Discussion Starter #5
Awesome,thank you.I guess they are master morons,:looney:
Discussion Starter #7
HAHAHA,I live in Beaverton,Oregon.I will be posting my X photo after I take my snow tires off.:draggin:
StepSIde
:funnyup: to verify that it is a chain simply remove the oil filler cap and look inside. it is the easiest way to make a fool out of theMASTER TECH!:selfbonk:
THATS A DUMBASS TECH...MOST BELTS ARE BEHIND A PLASTIC COVER..AND CHAINS ARE MOSTLY BEHIND METALL:selfbonk: :selfbonk:
Yep, your right.. I was doing my oil change and you can see it bright as day... Unless they are making the belts look like chains.. ROFL....
How often should the chain be checked and adjusted despite having VVTi?
The Chain Has A Self Adjusting Hydraulic Or Spring Loaded Tensioner...there Is Actualy 3 Chains Inside The Engine..one From The Crankshaft To Both Intake Cams And 2 Little Ones ( One On Each Side) From The Intake Cam To The Exhaust Cam The Little Ones Is What Your Seeing When You Take Off Your Oil Cap...they Usualy Last A Long Time About 150k To Over 200k
Do they need to be adjusted often to ensure proper timing?
1 - 15 of 15 Posts
