1 - 16 of 16 Posts
What seats can swap as pretty much direct fit? It's a 1997 extra cab lx with the split bench front.
Also, thoughts on adding a tach? Not happy about not knowing the rpm.
TIA
Are you aiming for twin buckets? If so, the economy approach would be to get a pair of same-era Taco buckets and have them (re-)upholstered (and maybe padded) to suit you.
If you're going to splurge on aftermarket seats you can put almost anything in there as long as you have the mounts. The mounts are the hard part.
The reason I mention reupholstering is that it can be tricky to match colors from different years during 1995.5 - 2000 (the exact fabric and trim colors shifted from time to time).
You'll need to swap the track / mount / base pieces on the driver's side. If I'm not mistaken you can re-use the mount on your current passenger ('40') side, because it's essentially a bucket to begin with. However, I think there will be a difference in the seat back tilt and / or forward travel (when sliding) compared with the pure bucket mount.
  • Like
Reactions: pimpRunner
Discussion Starter · #3 ·
Who has the best price on short shifter? In traffic it's getting annoying already having to row.
Discussion Starter · #4 ·
Was gonna go buckets but I'm lazy and don't wanna fab. Doing some hush hush work right now
135876
Discussion Starter · #5 ·
Sound pad in.
Doors sound padded.
Speakers in.
Now need to trim door panels to fit speakers. SMH
Discussion Starter · #6 ·
Still a bit of tuning and tweaking stereo needed. Sounds good tho
Moving onto lighting
Is there a list of all bulbs for the interior and quantity?
I believe it's 194 for cluster and was already able to figure out the dome.
But don't want to rip into cluster to get at all of the bulbs. Tnx in advance
Here's my old reference list for bulb types for the 1995.5 - 2004 era. It doesn't list quantities - sorry.
1995 - 1997 TOYOTA Tacoma (With sealed beam headlamps)
H6054
1997 - 2004 TOYOTA Tacoma (With replaceable halogen capsules)
9003
Parking light
1995 - 2004 = 168
2001 - 2004 = 4157 (optionally)
Front turn signal
1995 - 2000 = 1156
2001 - 2004 = 4157
Rear turn signal = 1156
Tail light = 1157
Stop light = 1157
High mount stop light
1995 - 1996 = 921
1997 - 2004 = 168
License plate
1995 - 1996 = 168
1997 - 2004 = 194
Back up light
1995 - 2000 = 1156
2001 - 2004 = 921
Front sidemarker = 168
Glove box = 74
Dome Light = DE3175
Step/Courtesy light = DE3021 / DE3022
Trunk/Cargo area
1995 - 1997 = DE3022
Instrument - General = 194
Discussion Starter · #8 ·
Step and glove box lights? Imma need to search a bit more for those. Sounds like maybe the sr5?
As always @Enola Gaia much thanks.
Is there a count on the cluster bulbs? Looks like just 2. But wanna have in hand before I rip it apart to change over. And is there a listing for hvac? (Not even sure mine has lighting. Been a few days since I have had out in the dark)
... Is there a count on the cluster bulbs? Looks like just 2. But wanna have in hand before I rip it apart to change over. ...
FWIW ...
The 1995.5 - 1997 cluster circuit documentation seems to indicate 4 bulbs for illumination in both the tach and non-tach clusters.
  • Like
Discussion Starter · #11 ·
Cluster has 4x 194 (158?) bulbs 2 with the green c0ndoms for cluster and 2 for blinkers
There is a series of 74 for the warning lights and a 74 in the hvac head(w c0ndom).
Not: do not replace the srs warning bulb with led. It's negative switching and has some voltage bleed through. Has to be incandescent.
Now I have to work on the dimmer, oe dimmer does not bring LED back to a acceptable brightness, so there's that.
Car Speedometer Vehicle Automotive lighting Odometer
Discussion Starter · #12 ·
Anyone already do the math or have a part for led that will dimm enough? The oem resistor does not have the range to actually dim led due to low circuit amperage
Anyone do a 95-97 conversion to an 01-04 headliner? @Enola Gaia ya hear of this?
Off hand, I don't recall it being done, and I can't locate any past thread(s) reporting it had been done.
If you're asking about a direct transplant ('01-'04 into '95.5-'00) I'm not sure it will work. The roof panels (sheet metal) have the same part numbers for both Regular Cab and XtraCab models, but I want to say there were still differences in the roof reinforcements and interior trim that might prevent the installation of a rigid ('01-'04) headliner into a '95.5-'00 model that had a bow-hung headliner.
If you're willing to track down suitable material and custom-fit it you'd still be stuck with forming the custom liner to match the roof contour.
Discussion Starter · #16 ·
Reason is I found someone with a Headliner for sale for 60$ and I think it would look good plus give me the ability to add sound padding to ceiling. Just running on a thought
1 - 16 of 16 Posts
