How about a 13" subwoofer ?I'm looking at getting a sub for my 2008 double cab Tacoma, and all I see are 8" and 10" enclosures. I searched on here but couldn't find anything about if a 12" would even fit.
Thanks in advance for your help!
Here another one by soundstream : http://www.soundstream.com/AudioProducts/Subwoofers/stealth.htmI just looked over the link, and if I can't fit the 12" i will for sure look at this! Thank you for the link!:waytogo:
Garbage ?? I just hooked up the Power Acoustik 13BX in my 03 double cab, and it actually sounds pretty soild, I had a hard time building those angled enclosure that small, plus you 'll going to need to buy tools and supply to build the box, of borrow from someone. Shops here charges 250.00 for a custom enclosure.just build one. those 2 listed are garbage and are basically the same thing (power Acoustik owns SoundStream now)
Buy a bunch of tools? The only tools you need is a jig saw and a drill...or if for some reason you don't have a drill, a hammer will suffice. Supplies include wood glue, screws, and a silicon sealant if you're doing a sealed box, which are things a lot o people have laying around in their garage.Garbage ?? I just hooked up the Power Acoustik 13BX in my 03 double cab, and it actually sounds pretty soild, I had a hard time building those angled enclosure that small, plus you 'll going to need to buy tools and supply to build the box, of borrow from someone. Shops here charges 250.00 for a custom enclosure.
When I found those boxes online when I was doing my search, with only 5" bottom and 2.5" top I had to try it out.
Crazy TRD Sport, whatever you choose post back I would like to know what you went with...
jig saw and drill? wtf are you making, a stool in woodshop? thats fcuking ghetto, he'd be better off with the prefab box listed.Buy a bunch of tools? The only tools you need is a jig saw and a drill...or if for some reason you don't have a drill, a hammer will suffice. Supplies include wood glue, screws, and a silicon sealant if you're doing a sealed box, which are things a lot o people have laying around in their garage.
Building an enclosure is the best way to go 90% of the time.
