+12 offset wheels on a Tacoma 2wd?
3302 Views 2 Replies 3 Participants Last post by  epa4wd
Hi everybody,
I have the opportunity to buy Ford Ranger Fx4 Alcoa wheels for
a cheap price. They look very good, the bolt pattern is the same
as my truck but i'm not sure about the +12mm offset. Will it go
out too much from the fender? Will it look good? I would like to
get your advice please.
Thanks,
Mat
2007 Tacoma 2wd
1 - 3 of 3 Posts
(1) Welcome to CT! ... :waytogo:
(2) What are the size spec's (especially the width) on the Ranger rims? :shrug:
(3) What are the size spec's on your current rims?
with +12mm offset, the wheels will probably stick out a little from the fenders, but if you are going for the offroad look, with a small lift it should look very good. Also check the center bore size of the Ranger wheels Im not sure if its the same or bigger than ours.
1 - 3 of 3 Posts
