1st Gen 2.4
Recently changed my water pump since it was leaking out of the weep hole at 126k miles on my 2001 Tacoma 5 lug 2.4L. Changed the fan clutch too since they share the same pulley. When the truck gets up to operating temp I've noticed that it's much quieter when I hit the gas and accelerate. Before this it would always have that loud air induction noise that I assumed was coming from my K&N intake.
Thoughts? Is this normal and an indication that my old fan clutch was failing or already busted? Thanks in advance.
That's a new one on me ... I don't recall this being mentioned before.
  • Like
Reactions: makotako
1st Gen 2.4
Discussion Starter · #3 ·
Maybe "quieter" isn't the best word to describe it? Smoother maybe? Sounded like it usually does while I had it running with the coolant funnel on the radiator to burp out all of the air after the water pump job. Went to twist the throttle body a couple of times and then it started to sound the way it does now.
It could have been worn bearings in the water pump or fan clutch you'd previously heard when you accelerated.
I'm not sure how twisting the throttle body - even if it shifted something or opened up a point of leakage - would account for the noise reduction (unless the previous noise you'd heard wasn't coming from the water pump or fan clutch at all).
