Quoted: 28 Post(s)
Re: 2001 Tacoma Quad Cab Prerunner Turbo
There's not a ton of documentation so far on the WWW regarding installation of CXRacing 5vz kit yet, so I'm gonna document any troubles I run into.
First trouble I ran up against was the installation of the passenger side manifold. The bottom and rearmost 2 nuts are impossible to get on and torque down unless you remove your starter. No big deal, just remove the 2 14mm bolts and pull it out of the bellhousing and out of the way. I didn't have to remove the plug or the positive terminal.
I eventually maybe want to run e85, so does it make sense to get mapecu3 so I can advance timing? Or should I go with AEM FIC and just not pull timing. When I was running stock ECU and spray methanol it was really strong with just no timing retard, don't know if I was leaving easy power on the table by not being able to advance. Does anybody have a suggestion?
2001 Tacoma DCSB PreRunner | 5vz | turbo | injectors | computer | 7.8 660'| 9.9 1000' |
