I need new tires for the 99 Tacoma 3.4 V6 SR5 Xtracab that i just bought, the tires that are on there now are 31x10.50R15 LT (BFGoodrich All-Terrains) theyre on the stock T15x7JJ rims. Can i put larger tires on them than stock? Im also planning on lifting the truck, should i just wait until then to get new tires?
Which is more important to you - the size of the eventual tires, or the amount of eventual lift?
If you get bigger tires now, then you'll have to figure out which lift approach will accommodate them. If you go for a particular lift, then you'll need to figure out which tires will fill things out like you want.
