1995 3rzfe just quit running. Cranks but won't start - Toyota Tacoma Forum
post #1 of 6 (permalink) Old 05-18-2019, 09:50 PM Thread Starter
Truck was running great all of a sudden it quit like I switched it off. I have checked all fuses and grounds but have no spark or fuel and obd2 will no longer communicate.
Swanky is offline
post #2 of 6 (permalink) Old 05-19-2019, 07:17 AM
Quoted: 366 Post(s)
Re: 1995 3rzfe just quit running. Cranks but won't start
(1) Welcome to CT!
(2) What were you doing when it quit? Did it die while you were driving, or did it simply fail to start one day?
(3) Does this Taco have any engine or fuel or electrical modifications?
post #3 of 6 (permalink) Old 05-19-2019, 07:21 AM Thread Starter
Just died while driving no indication at all. Truck is stock 1995 4x4 with 3rzfe. Starting to wonder if it's the circuit opening relay.
Swanky is offline
post #4 of 6 (permalink) Old 05-19-2019, 09:27 AM
Quoted: 366 Post(s)
A blown 7.5A STA (Starter) fuse might explain it. This would kill the Circuit Opening Relay.
The same could be said about the 7.5A IGN fuse and the EFI Relay.
A broken / bad connection to the ground point would also disable these relays:
EFI Relay = Ground Point EA (left / driver-side front fender; inside engine bay)
Circuit Opening Relay = Ground Point ID (behind the left kick panel)
If the ECM had detected a fail-safe condition that would kill the engine, but the OBD port should still work.
post #5 of 6 (permalink) Old 05-19-2019, 09:33 PM Thread Starter
After a lot of checking and testing I believe I've found the problem. Leaking valve cover gasket leaking oil into distributor connector resulting in a direct short in distributor blowing 30amp A2 fuse. Without connector plugged in fuse doesn't blow and obd2 connects but plug connector into distributor and instantly blows fuse. I will order new distributor tomorrow.
Swanky is offline
post #6 of 6 (permalink) Old 05-20-2019, 08:33 AM
Quoted: 366 Post(s)
That's a new one on me. Glad you found the source of the problem.
2rz cranks but wont start Boosted_Taco 1995.5 - 2004 39 12-08-2016 03:50 PM
96 2rz cranks/won't start only when hot on hot day rickalders 1995.5 - 2004 23 06-13-2014 08:18 PM
Won't start, won't crank, won't show key is in ignition, etc UndefinedTaco 1995.5 - 2004 7 10-31-2009 12:21 PM
Looking for 2.7 3RZFE blocks and cranks!!! Paradise Racing Parts and Accessories 6 09-12-2006 07:37 PM
Looking for 2.7 3RZFE blocks and cranks!!! Paradise Racing Wanted 3 09-12-2006 07:21 AM
