Afr sensor issues plz hep - Toyota Tacoma Forum
post #1 of 9 (permalink) Old 02-02-2019, 08:36 AM Thread Starter
Truck 2002 tacoma 2.7 dblcab auto. So i replaced my bank 1 sensor 1 with factory 89467-35050 due to poor mileage and then immediately got a p1130, p0171 and coolant temp insufficient for closed loop. I have flushed coolant with toyota red and replaced the temp sensor at back of block and maf sensors with oem toyota parts to no avail. Any tips this is driving me nuts?
DreaperA is offline
post #2 of 9 (permalink) Old 02-02-2019, 10:39 AM
Quoted: 344 Post(s)
Re: Afr sensor issues plz hep
First thing to do is go back to the beginning ...
Was there a specific code being thrown that led you to swap out the Bank 1 Sensor 1 A/F sensor? If so - what was / were the code(s)?
The simplest explanation is that either:
- the new Bank 1 Sensor 1 sensor is bad
or
- the Bank 1 Sensor 1 circuit is bad (short or open circuit), possibly as a result of something that happened during the installation
This is a single thing that would explain every else you've reported.
post #3 of 9 (permalink) Old 02-03-2019, 10:47 AM Thread Starter
I had a clogged cat replaced it no cels but still bad mileage noticed my fueltrims wouldnt move so figured that and mileage of truck ill just replace the afr. Just havent ever gotten a defect from toyota before
DreaperA is offline
post #4 of 9 (permalink) Old 02-03-2019, 03:36 PM
Quoted: 344 Post(s)
Have you checked to ensure you don't have any exhaust leakage after replacing the cat?
Exhaust system leakage could cause the CEL's you're getting.
post #5 of 9 (permalink) Old 02-04-2019, 08:40 AM Thread Starter
I havent been able to locate any exhaust leaks and if ther is one im just missing it would be post afr sensor so i wouldnt think it would do anything to the air mixture
DreaperA is offline
post #6 of 9 (permalink) Old 02-04-2019, 01:42 PM
Quoted: 344 Post(s)
There's a post-cat sensor that also feeds data to the ECM, which compares it to the pre-cat readings.
If the comparison doesn't meet spec's, a code is thrown. I'm not sure it's any of the codes you've been getting.
post #7 of 9 (permalink) Old 02-04-2019, 06:12 PM Thread Starter
Nope no p0420 with or without my urd o2 sim. Just have a code for closed loop coolant, lean bank 1, and sensor 1 circuit malfunction
DreaperA is offline
post #8 of 9 (permalink) Old 02-04-2019, 08:14 PM
Quoted: 344 Post(s)
Thanks for the additional info. OK, then ...
I still think it's a bad sensor or a wiring problem in the sensor's circuit. Or at least I hope that's all it is. For example, it could be a faulty ECM.
post #9 of 9 (permalink) Old 03-21-2019, 01:28 AM
waynebravo is offline
PLX AFR Gauge issues? Slick Nick Performance 8 10-11-2010 05:13 PM
need hep with a tach install tacotina Interior/Audio/Electronics 1 11-19-2008 07:47 PM
Check Engine light on! PLZ HELP! PLZ HELP! 97YoterS Performance 7 06-15-2008 01:00 PM
AFR Calibrator Target AFR...?? Gadget..?? Mano Performance 14 02-28-2007 09:20 PM
MAF sensor calibrator or AFR sensor calibrator? BlackSunshine916 Performance 9 10-06-2006 05:55 PM
