Spare Tire help! - Toyota Tacoma Forum
post #1 of 9 (permalink) Old 12-04-2004, 10:37 PM Thread Starter
sstyota's Avatar
Spare Tire help!
I lifted my mini and now comes time for the spare tire question. Can I just go buy a used 31x10.5 R15 tire and mount it to the stock spare wheel? I know 29" is the largest u can go on a 15x6 wheel, but will mounting a 31" tire on it work? Will it wear the tire out even if I am not riding on it?
sstyota is offline
post #2 of 9 (permalink) Old 12-04-2004, 11:10 PM
George4drV6's Avatar
Re: Spare Tire help!
it's the width not the height that matters. Id ont know if you can mount a 10.5" wide tire on a 6" rim. I mean you can get it on the rim, but its not a good idea.
George4drV6 is offline
post #3 of 9 (permalink) Old 12-04-2004, 11:22 PM
99TRDTaco's Avatar
The width would be fine for a spare the thing to be worried about is is the backspacing correct on your factory spare.
99TRDTaco is offline
post #4 of 9 (permalink) Old 12-04-2004, 11:23 PM
i have 31 x 10.5 on a 15x 6 in rim. works fine.
rednecktaco is offline
post #5 of 9 (permalink) Old 12-04-2004, 11:46 PM Thread Starter
sstyota's Avatar
Well if my factory spare works on the suspension lift with a stock tire, shouldn't it work just as well with a 31" tire?
sstyota is offline
post #6 of 9 (permalink) Old 12-04-2004, 11:53 PM
it should go in the stock place for a 31
post #7 of 9 (permalink) Old 12-05-2004, 12:02 AM Thread Starter
sstyota's Avatar
well i mean shoudn't it fit on the hub if it fits with the 26" stock tires? A 31" tire shouldn't cause any backspacing problems right?
sstyota is offline
post #8 of 9 (permalink) Old 12-05-2004, 12:07 AM
it would be the rim not the tire causing backspacing probs, um. if your stock wheels fit and have bout a inch or so spce between the spindle and tire then the 31 10.5 should fit. in theory.
post #9 of 9 (permalink) Old 12-05-2004, 12:50 PM
99TRDTaco's Avatar
Well the thing is that the tire is going to be wider so if the stock tire is close to any of the suspension then putting a wider tire on there may cause it to rub. The reason I bring this up is because on a 4x4 or prerunner the widest tire you can run on the stock wheels is an 11.50 because anything wider will rub the upper control arm. (I know you have a mini I was just using that as an example)
