04 Tacoma wider fenders? - Toyota Tacoma Forum
post #1 of 5 (permalink) Old 06-27-2016, 09:49 PM Thread Starter
Quoted: 5 Post(s)
Hi,
I have an 04 Tacoma I'm planning on starting a build thread on.. just trying to work out some kinks first, so I can make some quick progress in the thread...I bought the motor from "Sangle" on here...
I have a 2004 2wd 4 cylinder are there other truck models like 4x4 or SR5 that come with wider front fenders?
I know on some of my earlier tacomas the bed was already wide and it was necessary to run 4x4 fenders up front to match the width in the rear...
I"m looking to run 255-40-17 with a 17x9.5 +18 RPF1 and the rim is sticking out a bit in front , but close to flush in the rear...
Cheers again and thanks for any feedback
build coming soon... Competition Clutch Twin Disk, Gato Performance intake with RMR throttle body, Paradise Racing spec-parts long block with Paradise Header and Precision turbo, ID injectors, Haltech ECU (Platinum Sport 1000) , ETS EVO fmic, 8" rear end with Supra lsd swap, hopefully relocated motor, custom driveline with R155 swap, definite weight reduction (I"ve been putting in some time) simplified wiring harness-- will definitely be learning how to do better..., Tilton Floor mount pedal box, relocated fuel cell- AN fittings throughout, and custom 5 link with bilstein motorsport coils, Evo 10 Brembos front and rear...(may change) my goal is no more than 2500 lbs. and 500 whp... I will be posting dyno graph...
... hoping to do stock fenders, though will do fiberglass if I have to... I just haven't found a near stock size fiberglass fender without a lot of rise and extra width for offroad size tires...I'm ok with going a bit wider (2" would be perfect) but I don't want a big tall fender gap over my little tires...
Thanks!
Jimountain is offline
post #2 of 5 (permalink) Old 06-28-2016, 07:40 AM
Quoted: 348 Post(s)
Re: 04 Tacoma wider fenders?
During the 2001 - 2004 era, the front fenders were all the same as far as dimensions are concerned.
The only difference was that some were pre-drilled with holes to attach OEM fender flares on some 6-lug (4X4; PreRunner) models with certain trim / package options.
post #3 of 5 (permalink) Old 06-28-2016, 09:01 AM Thread Starter
Quoted: 5 Post(s)
thanks,
can I confirm what years the 4x4 fenders were indeed wider?
I had them on my 1993
truck changed in 1996 (95.5)
if I could get them for a 1996 and do something like change the headlights...and things fit close enough with the grill... I could make that work...
just trying to figure out my options and find something that might work... where I could hit up some junkyard and try some stuff... would be nice to have some level of certainty before spending money...
I've been learning the hard way lately.... : )
cheers again,
post #4 of 5 (permalink) Old 06-28-2016, 11:53 PM
Quoted: 348 Post(s)
Originally Posted by Jimountain View Post
thanks,
There's not really any way to figure out fender width / depth from the factory spec's.
The overall widths were uniform within any given year, but overall width could be measured anywhere (not specifically at the front fenders).
The only other measurement Toyota routinely published was the track (width). Track measurements varied a lot - 5-lug different from 6-lug; variations among models. However, track is measured between centerlines of the tires / wheels, and this doesn't directly indicate anything about the width / depth of the fenders.
If you try to transplant an earlier (1995.5 - 2000) Tacoma front onto yours, you'll end up doing an entire front clip swap. The earlier fenders (alone) won't visually line up cleanly with the rest of your 2001 - 2004 front body components.
post #5 of 5 (permalink) Old 06-29-2016, 09:41 PM Thread Starter
Quoted: 5 Post(s)
Okay,
thanks again... I'll look up the visual differences between the two.. and see if a front clip swap might be in order...though I already purchased a fiberglass hood... Cheers again
sacramento ca 2001 tacoma 2wd fenders or 97 4wd fenders silentj95835 Wanted 4 08-14-2010 07:58 PM
97-00 Tacoma 4wd fenders fit on 96 2wd Tacoma? Cheiz Body / Structural 2 01-31-2008 10:23 AM
Interested in wider Tacoma Bedsides??? Up Chuck Chino Off Road 0 10-06-2004 07:24 AM
wider glass fenders MillerTime Body / Structural 16 07-12-2004 11:58 PM
what fenders are wider minit97 Body / Structural 2 10-24-2003 01:57 AM
