What size should I go with - Toyota Tacoma Forum
post #1 of 9 (permalink) Old 11-03-2015, 01:12 PM Thread Starter
Whats goin on guys? Got an 01 and wanna do the 3/4 balljoint and block drop in spring and wanna go with 17s for wheels possibly. Question is if I do 17s what size tire will work best to fill the wheel well but not rub? Also if you guys got any pics of the same thing that would be rad to see for reference
Pickle is offline
post #2 of 9 (permalink) Old 11-10-2015, 04:45 PM
QA1 Founding Father
LilWhtTaco's Avatar
Re: What size should I go with
its not necessarily the tire size that is the determining factor. its the width and offset of the wheel.
for reference i have ran 17x7.5 +38 wheels with 225/45/17 tires on 2wd fenders and a 3/4. fit nicely.
LilWhtTaco is offline
post #3 of 9 (permalink) Old 11-10-2015, 04:55 PM Thread Starter
Cool thanks man. Got any pics of it?
Pickle is offline
post #4 of 9 (permalink) Old 11-10-2015, 06:59 PM
predator's Avatar
also use a tire/wheel calculator and try get closest to stock size so your speedo is accurate..
predator is offline
post #5 of 9 (permalink) Old 12-10-2015, 02:03 PM
QA1 Founding Father
LilWhtTaco's Avatar
unfortunately i dont... that was a while back.
i wish i did have a pic
if you did a search, you should be able to find some photos.
post #6 of 9 (permalink) Old 05-23-2016, 06:58 PM
Hey guys. wasnt sure if a new topic would be necessary. I have an '02 tacoma xtra cab 2wd with stock wheels and tires. lowered 3/4 with bj flip and lowering blocks. Im getting noisy wheel rub on sharp turns (driveway) and coming off exit ramps (40+ mph only) in the front end. the rear end seems to be doing fine. Where do I start? Would prefer bigger wheels, but the whole wheel/tire offset specs get confusing. And do you think the exit ramp rub is more suspension related than wheel and tire?
Hollow is offline
post #7 of 9 (permalink) Old 05-23-2016, 07:08 PM
Quoted: 13 Post(s)
The rubbing is from the force on suspension... coming down off ramp and loading up the front end, it sinks down and makes em rub
Same thing with the turning, it transfers weight to that spring/shock and it drops..known as body roll as well
If it's doing it pretty much at a stop when turning, you may be hitting sway bar, or lower part of inner fender, or actual fender lip (you will have to look and find out exactly where it touches, should be kinda obvious)
Stiffer spring rates and shocks will help it
Smaller tires would give you more clearance between tire and inner fender which would reduce rubbing.
rcogan86 is offline
post #8 of 9 (permalink) Old 05-23-2016, 07:11 PM
Quoted: 13 Post(s)
As far as bigger wheels, just look up your tire size now on google, get a overall height, and try to stay close but just a little shorter then stock on new wheel. Example, if your tires are 25 inches now, stay around 24-25 on your bigger wheels.
Offset of wheel will depend on width of wheel to whether it will tuck or rub
rcogan86 is offline
post #9 of 9 (permalink) Old 05-25-2016, 01:14 AM
toycoma98's Avatar
KYB Monomax 565030
toycoma98 is offline
Need a little help, what size.... Chris D. 1995.5-2004 2 01-12-2013 01:09 PM
which rim size tire size? seamoose213 4x4/PreRunner Wheels and Tires 4 03-01-2007 09:53 PM
Lift Size And Tire Size 1luckyman 2005+ 3 02-22-2007 07:00 AM
what size are my tires? (Size scheme conversion) TheBeachCruiser 2wd Wheels and Tires 3 04-09-2006 04:59 AM
T3/T4 size TRDStreetFighter Performance 7 07-03-2003 04:03 PM
