Turn a 2RZ into a 3RZ? - Page 3 - Toyota Tacoma Forum
 1Likes
post #21 of 28 (permalink) Old 09-27-2011, 09:21 AM
Quoted: 7 Post(s)
Re: Turn a 2RZ into a 3RZ?
Originally Posted by auto authority View Post
dont forget, pin height and rod lenght change. the 3RZ block is taller.
also the 3RZ crank is a forged steel crank vs the 2RZ is a cast crank, making the 3RZ a stronger crank. i would suggest use the complete 3RZ block and remove the balance shafts.
/\ /\ /\ /\ Exactly... LCE has balance shaft removal kits...
post #22 of 28 (permalink) Old 09-27-2011, 09:42 AM
So just so I am 100% clear. I can run a 2rz head on a 3rz block correct?
Also, with a balance shaft delete, how much will vibration increase?
96 Tacoma- Reg cab Base 2rz 5spd. 1.5" Day Star Coil spacer, 15" jeep wheels, SR5 gauge cluster and factory clock, Shifter console w/ cup holders.
COMAtized99 is offline
post #23 of 28 (permalink) Old 09-27-2011, 12:16 PM
671taco's Avatar
2rz and 3rz motors use the same head. The only difference is the longer stoke on the 3rz motors. Just take note that 3rz motors are more prone to rod failure when boosted!
BOOSTED 2RZ @ 434hp 368tq @ 18PSI/ OEF 10-11
671taco is offline
post #24 of 28 (permalink) Old 09-27-2011, 12:31 PM
Awsome! Thank you! I just wanted to be 1000000% sure. I dont plan on boosting my motor. This is my DD, and I have a heavy enough foot.
post #25 of 28 (permalink) Old 09-27-2011, 08:53 PM
turbotacoman's Avatar
Yeah, the head is exactly the same on the 2rz and 3rz. The 3rz block is taller by 3/4". If you look at the dipstick tube either engine you will see 2 different bolt holes. One is used on the 3rz, and the other on the 2rz. The block height differs by the distance between the centerline of both holes. The blocks are different and the crank, rods, and pistons are in no way interchangeable between engines. Don't even try. I have done major research on this subject.
Taco is back on the road!! stock 3rz powered now.
turbotacoman is offline
post #26 of 28 (permalink) Old 09-28-2011, 06:30 AM
Maybe you can answer another question for me. I plan to build a 3rz to replace my 2rz. I am going to reuse my current 2rz head. That means 2rz intake, TB, Injectors, cams... Everything. I figure I will need a 3rz timing set.
1. Are the cams the same between the motors? will there be any special parts I need to run a 3rz timing set on 2rz cams?
2. Will my ECU throw a code now that there is going to be more air in the motor? (longer stroke pulls in more air)
3. Will the ECU be able to feed enough fuel to the engine threw 2rz injectors.
Maybe im over thinking this, I dont mind sourcing a 3rz computer and injectors, but would rather save the money.
post #27 of 28 (permalink) Old 09-28-2011, 09:11 AM
My truck came with a 2rz, and currently has a stock 3rz with 2rz injectors and a 2rz ecu. No codes or anything. Runs great.
The cams are identical between engines. the timming set should be all you need.
RyanV likes this.
post #28 of 28 (permalink) Old 03-05-2019, 03:43 PM
So I can transfer all the external parts from my 2rz on to my 3rz with out any issues??
SCTACO96 is offline
