GM Knock sensor mod - Toyota Tacoma Forum
post #1 of 3 (permalink) Old 03-17-2019, 10:16 PM Thread Starter
GM Knock sensor mod
04 5VZ. TRD S/C 7th injector. No lights, new MAF, upstream AFR sensor, good fuel pump, new plugs/wires, cats are good.
I’m having an issue when I go WOT. It seems to get to a point when it bogs and looses power. Also wants to ping pretty good in the 4000RPM range for a second, and AFRs always hit low 11s even with having the fuel map 1.1ms across the board. I’m thinking this is a knock sensor issue even though I I’m not throwing codes.
I’m going to attempt the GM knock sensor mod but I want to be 110% certain I know I have everything I need and not run into any issues while I do it.
Step 1. Drain some or all coolant from block.
Step 2. Remove S/C and lower manifold.
Step 3. With the new Toyota Knock sensor wiring harness, GM 800 harness, and knock sensors splice the GM to the Toyota and replace the old one.
Step 4. Plug the sensors in an button it all up.
Am I missing anything?
Has anyone else had the same issue with no CELs and resolved it with the GM knock sensors?
John Doe is offline
post #2 of 3 (permalink) Old 03-19-2019, 09:56 AM
kurt4726's Avatar
Quoted: 78 Post(s)
Re: GM Knock sensor mod
I had power loss and no CEL due to the stock knock sensor picking up phantom knock. The GM knock sensor fixed it.
'02 4x4 3rz-fe. he351cw Turbo. Treadstone manifold. Megasquirt. 550 primaries 500 secondaries. Vortech inline fuel pump. Intercooler. Flex fuel. R150F trans swap. ACT T020 & DTX-137L disk. 413whp 479wtq 23psi on E85. Kazuma LSD. LCE 10:1 pistons & rods.
kurt4726 is offline
post #3 of 3 (permalink) Old 03-19-2019, 04:54 PM
Quoted: 27 Post(s)
If the sensors detect knock, they don't throw a code they just pull timing. The only time they throw a code is if the ECU cannot communicate with the sensors or they communicate a voltage out of range. You could most definitely be experiencing the phantom knock I've heard about.
If you have a bluetooth code reader and the Torque Pro app ($5 and $30 off Amazon) you can view you total timing advance on the readout. It's very helpful for diagnosing these sorts of things without having to spend all the time and money changing knock sensors only to find it wasn't the problem (though it probably is).
I think the last time I logged my timing it was at 15 degrees total timing advance at WOT. But that was my old engine with compression & other issues.
S/C'd with 2.1" pulley, 310cc injectors, AEM F/IC 6, methanol injection, Airaid intake, Doug Thorley headers and deckplate mod.
Gamefreakgc is offline
Knock Sensor (CT-zen flatboy; GM / Chevy Sensor Transplant) flatboy Performance 7 10-24-2017 09:59 PM
GM knock sensor conversion dropthattaco Performance 55 05-02-2017 09:26 PM
knock knock bwill808 Performance 20 09-10-2011 04:06 PM
gm knock vs taco knock sickboy23 Performance 11 01-18-2010 08:10 PM
knock knock, who's there.... olyota Maintenance 35 04-13-2009 08:39 AM
