Installing 05+ oil pressure gauge - Toyota Tacoma Forum
Old 04-29-2009, 10:40 PM Thread Starter
I have an 06 double cab with the 4.0L and I am doing a gauge pod. I'm putting in a volt gauge and an oil pressure gauge. I'm not exactly sure how to go about installing the oil pressure gauge. I have found a lot of info on the older engines but nothing on the 4.0L. Some questions I have are:
where do I hook up the sender unit on the 4.0L motor specifically?
what fitting do I use?
when I remove the idiot light switch to hook up the sender unit, will the idiot light come on? (I'd rather not do a T fitting unless I have to)
Salem is offline
Old 04-29-2009, 11:19 PM
Quoted: 7 Post(s)
Re: Installing 05+ oil pressure gauge
You can always use a "sandwitch adapter" that goes between the oil filter and the engine block and has 1/6 npt ports in it
Old 04-30-2009, 11:59 AM Thread Starter
I have seen those but I would rather just use the idiot light port if at all possible. I am just concerned that if I disconnect the light sensor that it light up on my dash.
Salem is offline
Old 04-30-2009, 12:39 PM
Quoted: 7 Post(s)
Why dont you want to use the adapter the simplify things, I just did gauges on an 07 Suby STI and used one, I think it was less than $60 and it made everything really easy and I didnt have to mess with any other stuff, the stock senders were not modified in any way.
also the port in the block is metric and the gauge is probably an NPT 1/8" , so it wont fit without an adapter anyway, just trying to help ya...
Old 04-30-2009, 12:51 PM
QA1 Founding Father
LilWhtTaco's Avatar
actually i think its BPT... not metric. its horrible. i agree with Speed. make it simple before you get yourself too involved and cant turn back.
LilWhtTaco is offline
Old 04-30-2009, 02:09 PM
Tred's Avatar
The oil sender unit is a switch that completes the circuit to turn on the light. Disconnecting the switch will not flip the light on because it will kill the circuit. Try disconnecting the plug to see for yourself. If you're willing to part with the idiot light, then all you have to do is (probably) get a 1/8 BSPT to 1/8 NPT adapter.
Vrrm pssht!
Tred is offline
Old 04-30-2009, 05:27 PM
Quoted: 7 Post(s)
Yeah BSPD, I stand corrected....but just saying I think I would want my idiot light to work, since I dont glue my eyes to the gauge, but I probably will see a red light on the dash....so I could shut it down quickly...
Old 04-30-2009, 05:52 PM
Tred's Avatar
The truth is the idiot light only comes on at 3 PSI of oil pressure or something. You could get an aftermarket oil pressure gauge with a warning light, although these cost a whole lot more.
Vrrm pssht!
Tred is offline
Old 04-30-2009, 06:32 PM Thread Starter
Thanks for the feedback
Salem is offline
Old 07-05-2019, 06:47 AM
Resurrecting an old thread from the dead...
Is the gasket with those adapters pretty good quality? I'd think it would wear over time replacing the oil filter over and over.
Ted Hagler is offline
Fuel Pressure Gauge Hookup for 05+ my68ur8trd Performance 0 04-17-2009 09:47 PM
oil pressure bypass valve BlackSportD Performance 3 03-27-2009 07:45 PM
mechanical oil pressure gauge install sickyota Performance 4 09-26-2005 08:38 PM
Oil Pressure Gauge install Impulse2k1 Performance 22 09-06-2005 09:03 AM
Fuel Pressure Gauge -need help. Turbo357 Performance 11 12-12-2002 03:26 PM
