3.4 Crank pulley holding tool - CustomTacos.com Forum
Old 10-04-2007, 11:09 AM   #1
Rembrant
Veteran
Rembrant's Avatar
Tacoma: 2000 SR5 4x4
Default 3.4 Crank pulley holding tool
Hey boys,
Those of you who have done your own timing belt replacement on your 3.4's, what did you use to hold the crank pulley while you removed the main bolt?
I printed off the Timing Belt write-up from 4x4wire, which includes a rough diagram on how to make such a tool. Has anybody made this tool using these specifications? Did it work ok, or is there anything you would change in it's design?
I have everything else I need, I just want to get this part straight so I make the tool right the first time.
Thanks guys,
Rem
Rembrant is offline   Reply With Quote Quick reply to this message
Old 10-04-2007, 11:14 AM   #2
centextaco
Enthusiast
centextaco's Avatar
Tacoma: 2004 Toyota Tacoma Pre-Runner
Default Re: 3.4 Crank pulley holding tool
Chain Wrench
centextaco is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
URD Crank Shaft Pulley Installed QSVeilside Performance 30 10-06-2007 09:34 PM
5vz crank pulley and s/c pulley info! trdtoy Performance 0 11-22-2006 06:47 PM
New urd crank shaft pulley h2oplaydamian Performance 34 03-09-2006 07:08 PM
New urd crank shaft pulley h2oplaydamian Performance 1 03-06-2006 07:41 PM
New urd crank shaft pulley h2oplaydamian Performance 0 03-06-2006 04:12 PM
