haltech wiring diagrams for 3rzfe. with coils. - CustomTacos.com Forum
Old 06-14-2007, 11:22 PM   #1
Berad
Newbie
Tacoma: 98 toyota hilux
Default haltech wiring diagrams for 3rzfe. with coils.
Ignition wire :
Stock ecu (run it over to the ignition barrell the one in the stock loom cant support the power draw from the relays)
Throttle position sensor :
Stock ecu Yellow : (signal out)
Stock ecu Green/yellow trace : (5v input from ecu)
Stock ecu Light green/black trace : (Ground)
Cam angle sensor :
(dont need it if you set the injectors up to run batched)
Stock ecu Black : (ground) (the cam angle sensor is not needed)
Stock ecu White : (signal out)
Crank angle sensor :
the loom wire colors change from the plug going to the sensor and the plug going to the ecu, those combinations are from sensor to plug)
stock ecu Red (shielding)
Stock ecu Green (trigger)
Stock ecu Brown/White dots (ground)
Injector 1 :
Stock ecu Black/pink trace (12v)
Stock ecu Red/blue trace (ground)
Injector 2 :
Stock ecu Blue (ground)
Injector 3 :
Stock ecu White (ground)
Injector 4 :
Stock ecu black/pink trace (12v)
Stock ecu Red (ground)
to just use 2 injector banks ive linked injector 1 and 3, and 2 and 4 together
(note : opposite to how the wasted spark ignition works)
Coil packs :
stock ecu black/red trace (12v)
stock ecu blue/white trace (ignition trigger)
stock ecu brown (ground)
stock ecu white/black trace (misfire recognition/tacho) not used on aftermarket ecu's
thanks to richard for that diagram
as the diagram said ignition 1 output from the ecu goes to coil pack 1,4 . ignition ouput 2 goes to coil 1,3
the 3rz coils have built in ignitors hence the 3 wires instead of the 2.
Idle Motor
stock ecu
stock ecu havnt go that far yet.
stock ecu
stock ecu
NOTES : for people that dont know everything :P
  1. The crank angle sensor is magnetic NOT hall effect
  2. Cam angle sensor is used as HOME but not needed.
  3. The cas is a 34 tooth wheel, but in the trigger setup it needs to be put in as 68 tooth
    (i have trigger btdc set to 53 degrees and offset set to 4)
MICROTECH BASE MAP
http://lance.ugbox.net/Hilux/Modific...%2028-08-2006/
HALTECH BASE MAP
"i just need to host it and ill throw it up"
Berad is offline   Reply With Quote
Old 06-15-2007, 08:04 AM   #2
h0twh3els
Addict
h0twh3els's Avatar
Tacoma: 2006 Town and Country, 98 350 Tacoma..
Default Re: haltech wiring diagrams for 3rzfe. with coils.
Fuel pump hook up?
98 Tacoma crap box w/ swapped 350.
h0twh3els is offline   Reply With Quote
Old 06-15-2007, 09:05 AM   #3
mlf1
mlf1's Avatar
Tacoma: '98 Extra Cab
Thanks for posting it..... Very usefull stuff..
mlf1 is offline   Reply With Quote
Old 06-15-2007, 03:46 PM   #4
turbotacoman
turbotacoman's Avatar
Tacoma: 98 tacoma 3rz x-cab, 2005 tundra doublecab, '95 4x4 x-cab 5vz
x2
Taco is back on the road!! stock 3rz powered now.
turbotacoman is offline   Reply With Quote
Old 06-15-2007, 05:22 PM   #5
Berad
Newbie
fuel pump hook up ill have to have a sus in the car, its easy enough to find though trace it back from the pump, but ill find out sometime today for yas
Old 06-15-2007, 06:14 PM   #6
Enola Gaia
Enola Gaia's Avatar
For archival purposes, here's the diagram as an attachment ...
Old 12-10-2008, 07:46 AM   #7
turbotacoman
Hey Speed freak, this bump's for you!
Old 12-10-2008, 09:45 AM   #8
Speed Freek
Tacorvette enthusiast
Speed Freek's Avatar
Thanks Alan, I just joined that forum a few days ago, but it still wont let me see some of the pics, maybe I need to make a few posts there first.
Good info for me.....
CT is great, always members helpin you out...
BOOST BRIGADE I fabricate custom parts: HEIM STYLE STRUT RODS, FORWARD FACING INTAKE MANIFOLDS, and TRACTION BARS (5 LUG) contact me for more info @ www.Speed-freek.com or just PM me here THANKS!
Former Lexus / Toyota tech
Speed Freek is offline   Reply With Quote
Old 12-11-2008, 05:49 PM   #9
Stroked01SRunner
Enthusiast
Is the CAS a true 34 or a 36 with two missing teeth?
Stroked01SRunner is offline   Reply With Quote
Old 12-11-2008, 05:58 PM   #10
Speed Freek
Never actually counted but I guess it is 34, seems 36 would coincide with degrees though
Remote Starter and Alarm Wiring Diagrams derkdiggler Interior/Audio/Electronics 2 05-13-2007 10:31 AM
FTC Wiring diagrams for a 96 3.4 manual tranny ochizon Performance 7 06-21-2006 11:47 AM
DC Coils on Xtra Cab ToyotaJoe 4x4/PreRunner Suspension 1 07-29-2005 09:34 AM
Wiring Harness Question swampyankee Lights / Exterior Electricals 7 02-23-2005 05:46 AM
