Add LED to Factory Alarm??? - CustomTacos.com Forum
Old 12-16-2006, 12:39 AM   #1
blktaco58
Addict
blktaco58's Avatar
Tacoma: 06 tacoma 4x4 v6
Default Add LED to Factory Alarm???
I did a search and found similiar threads but didnt really answer my question-I have a factory alarm from toyota and i have a Blue led mounted above my ac vents(seen below). I want to wire the blue LED to the toyota unit so that it blinks when the factory alarm is on. The factory alarm has a small box that is mounted under the ash tray and is red. being that my truck is lifted-the alarm light on the factory unit is hard to see and isnt very bright. I wanted it more visible. Below is pics of the toyota alarm unit and three wires coming into to it-they consist of onbe thick grey wire to one side and two wires on the other(red and white/blk). Then those connect to a harness which is a 4 wires come out of. I am guessing i just hook up the red wire of the alarm unit below to the positive of the led???anyone done this or know-thanks.
blktaco58 is offline   Reply With Quote
Old 12-16-2006, 02:59 PM   #2
WildTaco
Addict
WildTaco's Avatar
Tacoma: 2005 4-Door Prerunner
Default Re: Add LED to Factory Alarm???
I'm not sure on that one. However, I do know that there are LED's out there that flash if you hook them up to power, to make it look like you have an alarm. I wonder if you need to get one like that and hook it up to the alarm wires.
WildTaco is offline   Reply With Quote
Old 12-16-2006, 05:24 PM   #3
willis
Grand Tacoholic
Tacoma: none
i have a varad led that i hooked up to my aftermarket alarm ... with mine i just cut the wires that were going to the wimpy red led that came with my alarm and ran them to my new varad unit ...
with a little wire following (which it looks like you have all ready done) and a test light or volt meter, you should be able to do the same?
willis is offline   Reply With Quote
Old 12-16-2006, 05:30 PM   #4
spyder041
damn
spyder041's Avatar
Tacoma: 1996 3.4L V6 Toyota Tacoma X-Cab 4x4
to get them to blink you need some kinda relay or something..I cant remember, but a friend of mine did it for his truck, only he put one in each headlight so they blink at the same time. Kinda creepy if your not used to it.
New Jersey: Home of where the strong survive, and the weak are killed and eaten.
http://www.myspace.com/wildjerseyfirefighter
Photo Sharing and Video Hosting at Photobucket
spyder041 is offline   Reply With Quote
Fs: 05 Skid plate and factory upgrade alarm uniden43 Parts and Accessories 2 01-03-2006 09:41 PM
Factory Alarm A96HondaAccordEX Interior/Audio/Electronics 5 07-09-2005 02:37 AM
i have a factory installed pursuit alarm and can't start the taco dretaco Interior/Audio/Electronics 3 06-06-2005 05:48 PM
Varad LED inplace of toyota factory LED darrcoma Interior/Audio/Electronics 10 04-22-2005 09:44 AM
Factory alarm??? hapa777 Interior/Audio/Electronics 7 10-18-2004 03:45 PM
