Remote Starter/Alarm problems - CustomTacos.com Forum
Old 12-14-2006, 07:56 PM   #1
DonkeyLips
Newbie
DonkeyLips's Avatar
Tacoma: 2005 Toyota Tacoma
Default Remote Starter/Alarm problems
This is my first post on the site (been a reader for a while, just haven't asked any questions). I need some advice from you experienced folks...
I had Pursuit Series 4 channel remote car starter with full feature alarm system (model PRO-9775T) installed on my 2005 Tacoma in January of this year. For some reason now, whenever I remote start the truck, the parking lights donít come on. When I get off the train every night, I have no clue if the remote starter actually activated or not. The lights donít even flash when I arm the alarm. What could be the cause of this? If you have any ideas, I'd greatly appreciate any and all advice. Thanks.
DonkeyLips is offline   Reply With Quote Quick reply to this message
Old 12-14-2006, 08:29 PM   #2
kevin_tall_guy
Veteran
kevin_tall_guy's Avatar
Tacoma: 06 Toyota Tacoma Prerunner Access Cab
Default Re: Remote Starter/Alarm problems
I have no experience with you particular remote start but it sound like you have either a loose connection in the wires that go to your parking lights or the remote start itself may be defective. Just a guess.
Mods: 2 10"Polk Audio MOMO MM2104 Subs, 2 Pioneer Premier TS-C720PRS,Polk Audio C500.1 amp, Polk Audio MOMO MMC6500, JL 450/4 4 CH amp, Blue Dash Lights, Carriage Works Grill, Snug Top, Tinted Windows, Debadged tailgate, 6" Procomp lift 17"Helo Maxx Rims, 265/75/17 A/T Tires. Cleared Headlight, Trendz Antenna,TRD Seat Covers.Flowmaster 40 Series Exhaust,Airraid Intake, Panosonic 7" In-Dash Touch Screen, Back Up Camera, Train Horn, Viper Alarm
kevin_tall_guy is offline   Reply With Quote Quick reply to this message
Old 12-14-2006, 09:32 PM   #3
SRakaSSS
Addict
SRakaSSS's Avatar
Tacoma: '04 Taco, 2.7L, Ext Cab, Auto. aka too damn slow!
Do your parking lights work even when not using the alarm, i.e. running lights?
"Take care to get what you like or you will be forced to like what you get."
- George Bernard Shaw
SRakaSSS is offline   Reply With Quote Quick reply to this message
Old 12-14-2006, 09:38 PM   #4
tacoturbo95
Addict
tacoturbo95's Avatar
Tacoma: 1995 Toyota Tacoma Turbo 2wd / 00 Tacoma Prerunner TRD V6
sounds like you have a blown fuse. The white wire coming from the alarm brain should have a 10amp fuse in it. Its probably blown.
tacoturbo95 is offline   Reply With Quote Quick reply to this message
Old 12-15-2006, 04:48 PM   #5
DonkeyLips
Newbie
DonkeyLips's Avatar
The parking lights only work when I actually go to turn them on. When I remote start the truck, they usually come on until I get inside and put the key in the ignition. When I get off the train at night (5:30 p.m. EST), I have no way of knowing if my truck actually started until I get to a distance where I can hear it. Tonight was one of those nights that it didn't start and I had no idea until I was there.
I have an appointment tomorrow morning with the place that installed it. They pretty much said the same things you guys said (blown fuse or loose wire). If they think I'm paying a dime, they're sorely mistaken...
Old 12-15-2006, 10:52 PM   #6
tacoturbo95
Addict
By the way nost installers use a t-tap style connection and they always fail. I solder my conections and rarely if ever do I have a problem. You might want to ask if they use these
Old 12-17-2006, 06:07 PM   #7
flowedtacoma
CustomTaco
flowedtacoma's Avatar
Tacoma: 2005 SW Double Cab
Any ideas why the remote start on my '05 won't start the truck with the first crank when it's the first time starting it in the mornin?
Not your everyday Tacoma...........
CT......not just a website......It's a way of life!!!!
flowedtacoma is offline   Reply With Quote Quick reply to this message
Old 12-17-2006, 09:58 PM   #8
tacoturbo95
Addict
Depends on what the cranking cycle on the alarm is. Normally if your truck wont start in just a few cranks the alarm will stop and then try over its a safety feature in the unit so it doesnt burn up the starter. If it wont start at all then its probably somthing in the alarm or a programming issue
Old 12-18-2006, 12:24 AM   #9
flowedtacoma
CustomTaco
i got ya. it's just weird, because it will start, but some mornings it will just crank, like the alarm can't give it the extra juice it needs in the morning. haha
Old 12-18-2006, 07:49 AM   #10
blackgts2002
Newbie
I would check the connection of the ignition wires..
also , you might be on to something as far as juice.. make sure that your remote starter was installed with a direct power line to the battery(fused of course). The factory ignition wires and 12 volt constants are not of size to provide all the power that the brain needs to run the vehicle... that could be your problem.
blackgts2002 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Where to get a remote? waldog Interior/Audio/Electronics 2 11-16-2005 09:50 PM
Question about remote wire current UofATaco Interior/Audio/Electronics 10 01-13-2005 10:19 AM
adding remote start to 2004 Tacoma Double cab spellow Interior/Audio/Electronics 8 11-04-2004 09:30 PM
Keyless Remote dilema (04-) LATacoma Interior/Audio/Electronics 1 04-20-2004 05:02 PM
