Throwout Bearing Noise: Real Problem or Minor Annoyance - CustomTacos.com Forum
Old 11-20-2006, 02:40 PM   #1
Tricky Matt
Newbie
Default Throwout Bearing Noise: Real Problem or Minor Annoyance
Since this summer, whenever my '04 5-speed manual is in neutral with the clutch out there is a distinct whine. I figured it was the throwout bearing and didn't worry about it.
I can't tell if this is a problem for me. It seems that the consensus is that it's not that big a deal. In every thread about this situation everyone has just said "Replace it when you replace your clutch". I've dug around the CT forums and it seems as if a bad throwout bearing is kind of ilke having a cavity in a wisdom tooth you are about to have pulled. Why fix the cavity (throwout bearing) when you are about to get rid of the tooth anyway (ie a clutch replacement).
A hideous analogy, I know, but I don't want to replace my clutch right now at 50,000 miles. Am I an idiot to wait or is it really no more than an annoying sound and I am ok to keep on driving without any worries?
Any input greatly appreciated!
Tricky Matt is offline   Reply With Quote
Old 11-20-2006, 04:25 PM   #2
redrunner
slow poke
redrunner's Avatar
Tacoma: '01 S-Runner
Default Re: Throwout Bearing Noise: Real Problem or Minor Annoyance
I believe a bad throw-out bearing (or release bearing) makes a "ticking" noise, or sounds like "crickets".
If you don't hear that, but you hear more of a whine like you described, I believe thats the synchros. I could be wrong, but mine has made that whine (more noticable when the truck isn't warmed up) since I can remember. I got the clutch replaced 3k miles ago, the whine is still there.
Either way, I'm fairly sure theres no emergency action that you need to take because of it.
<waits for someone else to chime in>
PIP: "the worst thing i had was i blew past a cop with the S when i dropped it in 2nd. So he heard the cat dying under the hood and flipped the lights immediately"
redrunner is offline   Reply With Quote
Old 11-21-2006, 12:07 PM   #3
mtkawboy
Enthusiast
Tacoma: 87 Toyota 4x4 pickup, 2006 Tacoma 2wd
Does it get better or worse when you push the clutch in ? They will go a long time but get progressively worse until they sieze up and ruin the pressure plate. If its not a loud squeal I wouldnt worry about it for now. Thats pretty low mileage for that problem to occur.
mtkawboy is offline   Reply With Quote
Old 11-21-2006, 01:07 PM   #4
lskustumz
lskustumz's Avatar
Tacoma: 2008 X-Runner
I had a similar problem when I got my clutch done, I had them replace the flywheel as well, with a brand new one, (no re-surfacing) and throw-out bearing with the TRD clutch. Felt great and no noises for the first three weeks. Then I had a kind of chirp, I thought it was the throw out bearing as well, so on my next oil-changed I had the dealer look at, (the same tech that put the clutch in), and turns out it was just the fork catching on the outside of the bearing. So a quick grease up and lube and it was just fine!! They told me throughout all there installs and repairs that it is very rare for a throw out to go bad, its usually something of a bigger problem that took out the throw-out in the process. Good luck to ya!!
lskustumz is offline   Reply With Quote
Old 11-21-2006, 04:46 PM   #5
Gadget@URD
Supporting Vendor
Tacoma: 2005 XRunner 422 RWHP
This is the way I think it works.
If you have the noise when it is in neutral with your foot off of the clutch, and it goes away when you push the clutch in, then it may be the pilot bearing or an input shaft bearing in the transmission.
If you don't have the noise when idling in neutral with the clutch out, and then the noise starts when you push in the clutch it is the throw out bearing.
Then again, who knows....
Gadget
Gadget@URD is offline   Reply With Quote
Old 11-21-2006, 06:54 PM   #6
talltacoma
Enthusiast
talltacoma's Avatar
Tacoma: 01 TRD SR5 ExtraCab 4X4 V6
My 01 started the chirping noise at 17K miles...only in the winter when its cold. I have 73K now, still chirps.
Support your troops. Airborne, all the way!
I fought the law and the law won. If you can't beat 'em, join 'em.
talltacoma is offline   Reply With Quote
America has a real problem... ComaJoe Off Topic 16 08-11-2006 08:40 PM
stumped.... amber00dak Interior/Audio/Electronics 8 10-18-2005 01:27 AM
Throw OUt Bearing TallTacomaGary Performance 30 05-05-2005 11:27 PM
Problem with Carrier Bearing SinCity_Rage 1995.5-2004 7 11-12-2003 04:38 PM
PROBLEM w/ Door Locks !!! 98madman Off Topic 1 05-07-2003 12:36 AM
