turn signal switch bad? - CustomTacos.com Forum
Old 11-04-2006, 09:42 AM   #1
98TacomaSR5
Member
98TacomaSR5's Avatar
Tacoma: 1998 Toyota Tacoma SR5 extended cab 2.4L
Question turn signal switch bad?
hello all,
my 98 taco has a turn signal issue, when I turn the turn sigal on for a right hand turn it clicks fast and repeately until I pull down slightly on the turn signal lever and then it starts blinking correctly. It's as if it goes to far up. When I push the lever down to make a left turn it works fine.
It's not the bulbs or the relay since they do work fine when I pull down on the lever, it's just annoying and I think it's getting worse.
I am thinking of the turn signal switch itself in the steering column from my research, has anyone else had this issue?
Thanks.
98TacomaSR5 is offline   Reply With Quote
Old 11-04-2006, 09:48 AM   #2
Proteus503
Moderator
Default Re: turn signal switch bad?
has the vehicle ever been used for towing? check for the presence of a trailer light wiring harness.... i've seen those cause lots of turn signal issues due to improper setup, grounding, etc.
Proteus503 is offline   Reply With Quote
Old 11-04-2006, 09:57 AM   #3
98TacomaSR5
Member
that is a great reply but it is not wired for towing, I thought of that too, stripped wires or a short back there. It looks like it did from the factory, well with alot more dirt.
Old 11-04-2006, 12:11 PM   #4
dropthattaco
www.ncp-power.com
dropthattaco's Avatar
Tacoma: 97 Taco 2.4L t-t-t-turbo
check to see if your brake lights do anything funny when you mess with the T/S switch. it sounds like that is what the prob is, but if your brake lights faulter also, that's another nail in the coffin. good luck!
Turbo, bitches.
dropthattaco is offline   Reply With Quote
Old 11-04-2006, 04:36 PM   #5
toylowta
Addict
toylowta's Avatar
Tacoma: 98 tacoma 5vz R.I.P.
I'd replace the bulbs on that side first. I've had them blink fast but at first glance it looked like all the bulbs were working fine but after replacing a rear bulb I saw that one was faulty.
toylowta is offline   Reply With Quote
Old 11-05-2006, 12:55 AM   #6
BatuKing
Enthusiast
BatuKing's Avatar
Sounds like a bad switch since you can move the switch and get it working.
BatuKing is offline   Reply With Quote
Old 02-02-2008, 04:41 PM   #7
BlackEagle
Newbie
Tacoma: 98 Toyota Tacoma
Hey 98TacomaSR5,
Are you still having problems with yoru turn signals?
I am experiencing the same problem with my 98 Taco.
I am afraid that it is the switch assembly. I'll let you
know what it turns out to be.
BlackEagle
BlackEagle is offline   Reply With Quote
Old 02-02-2008, 09:30 PM   #8
rednecktaco
I see what you did there
rednecktaco's Avatar
Tacoma: 11'grand cherokee, 12 mazda 3i touring HB
not had an issue but i have an extra switch, the one with the headlight part, i got it when i bought my intermitent wipers.
rednecktaco is offline   Reply With Quote
Old 02-03-2008, 06:28 AM   #9
todda68
Newbie
Tacoma: 2004 taco trd
I had a problem just like that in a 98 Ranger. I took the blinker arm off and cleaned it with contact cleaner and never had a problem again, but i did trade it in for my taco about a year later
todda68 is offline   Reply With Quote
blowing turn signal fuses pdmech73 Interior/Audio/Electronics 8 05-22-2010 04:15 PM
Help with some codes! trdtoy Performance 11 04-17-2008 09:25 AM
Road America, 18 laps and 1/2 tank of fuel OXI X-Runner Talk 4 10-16-2006 10:08 AM
turn signal and parking lamp switch wvuviv30 Lights / Exterior Electricals 4 06-29-2005 07:33 AM
turn signal light 03trdtacoma4x4 Lights / Exterior Electricals 6 08-03-2004 11:48 PM
