Additional precursor info: The A/FR I'm reading is coming from a gauge that's piggybacked onto the narrowband output. It is NOT "real" in the sense that it's coming from my wideband. The REAL A/FR is _hosed_.
Originally Posted by Greedy
Hey there mark! I had the same problem of sorts with mine - turned out that I had a bad unit though.
argh. And I paid for express mail to get this up here in a day.
Anyways, are you using your scan tool to tell when you go into open loop?
Yeup, the Auterra.
I know that with the bad unit I had in, it did not register as going into open loop untill about 9 psi - which at that point I was nearly at WOT when it should be switching anyways.
Right, that's exactly what I'm seeing.
Have you tried plugging in some numbers on your fuel map while in low boost and seeing if it positively effects your af/r's.
Yeup, and there's no change.
Originally Posted by tour4fun
Mark do you mean 14.7 only or more like swinging between 14.5-14.9?
Oh no, this is DEAD constant at 14.7. It's just like the ESC1 is spitting a solid voltage and nothing else. In fact, it's so dead constant that I had to force fuel in at idle to keep the engine running. The ECU was so convinced that things were dead-on perfect that it wasn't doing anything.
Originally Posted by MountainBiker
That is a feature of your Toyota ECU.
Ummm, no it's not. On a 96, the front O2 sensor is narrow band and swings wild in closed loop. That's a natural occurance of narrow band O2 sensors and with the ESC1 in-line, it stops happening all-together.
