Larger centerbore to smaller? - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > 2wd Discussion > 2wd Wheels and Tires
Old 01-12-2006, 01:09 PM   #1
tacoINtacoma
Lurker
Question Larger centerbore to smaller?
I know you have to hone out a lot of oem rims to fit a tacoma, but is there any ramifications of going the opposite way?
Reason I'm asking is I'm trying to sell my old wheels and someone that has a car with a smaller centerbore is interested in them.
Does it matter?
tacoINtacoma is offline   Reply With Quote
Old 01-12-2006, 02:18 PM   #2
Enola Gaia
Enola Gaia's Avatar
Default Re: Larger center bore to smaller
As long as their wheel setup can handle a lug-centric format (having the wheels centered solely by the lugs) it'll be OK. They might have to consider different lug nuts to achieve a safe / secure fitment, depending on what they've currently got.
Seems like I've seen spacer or adapter plates that are designed to help in fitting larger-bore wheels onto smaller hubs... Don't remember for sure, though...
Old 01-12-2006, 06:38 PM   #3
zero4
zero4's Avatar
Tacoma: 01' DCab 3.4L
Stock alloy Toyota wheels or aftermarket? I assume aftermarket and if so they're most likely lug centric type wheels, the kind that use acorn style lug nuts so they'll be fine.
Most factory Toyota alloy wheels are hub centric and use shank style lugs.
They also make hub centric rings that you can use but you'll have to figuree out what size ring you need and if that size is even available if it's an odd size.
zero4 is offline   Reply With Quote
What OEM wheels fit our (1995.5 - 2004) trucks? jw112 1995.5-2004 112 03-25-2013 11:28 PM
X-runner Turbo X-running X-Runner Talk 90 01-31-2008 08:39 PM
Can I run smaller pulley on stock injectors if my AFR is 11:2-12:01 240dude Performance 11 08-05-2005 09:18 PM
Centerbore / Lug-centric / Hub-centric tacomaman 1995.5-2004 8 07-24-2005 09:12 PM
SR: Supercharger: Pulleys: Larger or Smaller? cal-srunner S-Runner Talk 1 02-20-2003 03:26 PM
