What tires to go with on stock 15x6 steel rims? - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > 2wd Discussion > 2wd Wheels and Tires > 1995.5-2004
Old 11-21-2005, 11:40 PM   #1
TwoWheel2001
Newbie
Default What tires to go with on stock 15x6 steel rims?
I am looking for new tires on my wife's 2001 Tacoma base model with the 15x6 steel rims. I would ideally like to go bigger than the stock 205/75 but I don't want it to effect the speedo. Any help would be greatly appreciated.
TwoWheel2001 is offline   Reply With Quote
Old 11-22-2005, 12:56 AM   #2
tacoyota
Tacoma: 99 2.4 extra cab mini taco
Default Re: What tires to go with on stock 15x6 steel rims?
if you go bigger than stock u will affect the speedo...the larger the faster you will be rolling.
tacoyota is offline   Reply With Quote
Old 11-22-2005, 05:55 AM   #3
sc99taco
Veteran
sc99taco's Avatar
Tacoma: 99 Toyota Tacoma, 2WD, Std Cab.
http://www.customtacos.com/ubbthread...86&fpart=1
You could go with something like 235-65 which gives you the same sidewall height and pretty much the same overall diameter (0.1" smaller) on a wider tire... The site referenced in that post lets you put in whatever tire size you want and tells you how it affects the speedo.
Now... do they make such a tire? I dunno. I think that also might be the max width for a 6" wide rim. I'm not a tire guy though, so I don't really know the answer to that question.
sc99taco is offline   Reply With Quote
Old 11-29-2005, 05:17 PM   #4
Wingaling -Tacoma
Addict
Tacoma: 2005 Nissan Frontier Crew Cab Storm Gray Metalic 4x4
yeah they do make a 235/65/15. that is a common tire size for cars like grand ams and such. and you can put it on a 6 inch rim they will just pooch out a bit, like 2 mm or something like that, it would look good though.
Truck Pics m0f0
Wingaling -Tacoma is offline   Reply With Quote
Old 12-07-2005, 10:30 PM   #5
Chris D.
ADMlNAHATER
Chris D.'s Avatar
235-65's are your best bet..
I always use this tire calculator
http://www.miata.net/garage/tirecalc.html
When I went from the stock steelies to the 16" hyundai sante fe wheels, I use this calculator.. 225-60-16's and they look nice..
speedometer is hardly off at all..
they dont stick out either.. I did wheels and tires for less than 400 bucks..
(LEFT SIDE) 16x6.5 Hyundai Sante Fe wheels w/225-60-16 goodyear rs-a tires
(RIGHT SIDE) stock steel wheels w/205-75-15 tires
Old 12-07-2005, 10:39 PM   #6
teeque
Veteran
Tacoma: 98 Extra Cab 2WD
I recommend a 225/70/15 size.
teeque is offline   Reply With Quote
Old 12-08-2005, 10:37 PM   #7
Chris D.
ADMlNAHATER
Chris D.'s Avatar
teeque's the wheelman.. Id go with that..
