really rough idle? - CustomTacos.com Forum
Old 11-06-2005, 11:26 PM   #1
streetaco96
Member
Tacoma: 1996 2WD Standard Cab
Default really rough idle?
i have a 96 2.4L taco. As of right now...it's acting up! My idle is extremely rough. So rough that the entire truck shakes. I have an aftermarket exhaust so it even sounds really bad. when i start my truck there's a loud clicking sound coming from the back of the engine. It goes away after i hit about 40 mph. There's also a strange smell. Hard to tell where it's coming from...the actual engine or exhaust fumes. My check engine light flashes when i drive it. I haven't changed the timing chain yet. It has over 150000 miles already. Could that be the problem? i'm really confused about what it is. I wanna take it to the shop tomorrow but i don't wanna get ripped off and pay an arm and a leg.
HELP! any info or suggestions would be grateful.
streetaco96 is offline   Reply With Quote Quick reply to this message
Old 11-07-2005, 04:17 AM   #2
ochizon
back in black (tacoma)!
Tacoma: 1999 2.4L Tacoma, std cab 5spd
Default Re: really rough idle?
you are misfiring. Check the code, see what cylinder is misfiring, and check the spark plug. It could be as simple as a fouled plug. Then do a compression test. It could be a blown headgasket.
Are you noticing a lack of performance, like it really doesnt want to go at all?
ochizon is offline   Reply With Quote Quick reply to this message
Old 11-07-2005, 06:38 AM   #3
Firdaddy
Grand Tacoholic
Firdaddy's Avatar
Tacoma: 2001 Stepside turbo 06 Forester fxt
i agree with alex, also could be your cat .. well i dunno, the flashing c/e light is defintally a misfire
Firdaddy is offline   Reply With Quote Quick reply to this message
Old 11-07-2005, 10:51 AM   #4
Jarrett_B
Jarrett_B's Avatar
Tacoma: 2002 Double Cab SR5 4x4 Trd
i have a rough idle at occasional startup, its really low, but i haven't seen a check engine light, it starts up and idles really really low, the point of stalling, any idea of whats happening
this just started saturday when i was wheeling
Jarrett_B is offline   Reply With Quote Quick reply to this message
Old 11-07-2005, 12:36 PM   #5
Firdaddy
Grand Tacoholic
Firdaddy's Avatar
i'd check for any vaccum leak in your rig, mabey somethign was jarred off when wheeling..
Old 11-07-2005, 02:01 PM   #6
streetaco96
Member
yeah...my truck is definately lagging. It barely wants to move.
Old 11-07-2005, 02:27 PM   #7
01TACOMA SD
Enthusiast
01TACOMA SD's Avatar
Tacoma: 2001 Toyota Tacoma V6 Extra-Cab Trd...
I had a similar problem. Started my truck one morning and the idle was louder than usual. As I was driving to work the check engine light went on. Took it to Toyota Dealership and my 02 sensor gone bad. Bought a new 02 sensor and replaced it myself. Unplugged the battery to reset and remove the check engine light. rough idle was gone and also check engine light there after.
01TACOMA SD is offline   Reply With Quote Quick reply to this message
Old 11-07-2005, 03:04 PM   #8
Firdaddy
Grand Tacoholic
Firdaddy's Avatar
i'd defintally bet my money on the cat go dump the exhaust and see if the symptons presist.. althoght it might get worse since the lack of backpresure does that bad idle too...
Old 11-08-2005, 04:24 AM   #9
ochizon
Before we talk any more about catalytic converters, lets clear this up: THE FLASHING LIGHT INDICATES A MISFIRE. The lack of power is because 1 or more cylinders are not firing. GET THE CODE CHECKED, then get back to us.
Stop driving it, too!
Old 11-10-2005, 11:16 PM   #10
streetaco96
Member
I may sound like an idiot but when you say "check the code" you mean? and how would i go about doing it? I'm a beginner when it comes to certain issues pertaining to cars.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
