Welcome to CT Xboyblue
Hey Enola, got a ?
Say I wanted to go with a 20x8.5 rim and a 20x9.5" rim on the back, out of these offests what would you go with?
http://www.5zigenusa.com/w_h5zr20_2p.html
And just to pick your brain a little bit more, what size tire would you go with? Using a wider tire on the back.
http://www.miata.net/garage/tirecalc.html
There is a good inch and a half between the back wheel and the shock. There is about another inch and a half to two inches on the outside of the back that can stick out farther then stock.
Keep in mind I'll have a big brake kit and will need room for some fat calipers.
