Cleaning your MAF sensor: Fact vs. Fiction - CustomTacos.com Forum
Old 03-29-2005, 02:58 PM   #1
AKSHUNJ
AKSHUNJ's Avatar
Tacoma: 2K Xcab 4X4 3RZ TRD 5spd 260K miles
Default Cleaning your MAF sensor: Fact vs. Fiction
Only clean your MAF sensor when you SEE with your eyes that it is indeed dirty. There's no other reason to clean it. Don't clean it because you have a CEL and you figure that will fix the problem.
If you do see it is dirty and need to clean it, then use an electronics cleaner that has the following properties; leaves no residue and is safe for plastics. Make sure it is safe for ABS plastics. Many of the better electronics cleaners will crack ABS plastic. This is the plastic your MAF sensor, and the housing on the V6's is made from.
If your air flow sensor is dirty in most cases you will get a P0171 MIL. this code is for "system too lean Bank..." The system is indeed lean because the dirt or K&N oil that builds up on the air flow sensor is stopping the air from flowing across the hot wire.
If the air is not touching the hotwire then the ECU doesn't know it is entering the engine. The ECU is basing how much fuel is required on the throttle position, the MAF sensor voltage, and also from other feedback sensors such as the O2 sensors.
If any of that info from the sensors is bogus, (such as a contaminated hotwire) the ECU will see it and after it has operated out of it's programmed specifications you will get a Check engine light.
When it first happens you will have a diagnostic code that is pending and can only be seen with a scanner.
Feel free to add your $.02
AKSHUNJ is offline   Reply With Quote
Old 03-29-2005, 09:37 PM   #2
snwbdr
Grand Tacoholic
snwbdr's Avatar
Tacoma: '02 S/C V6 TRD 4x4
Default Re: Cleaning your MAF sensor: Fact vs. Fiction
I've seen people commenting on how they use a q-tip and rubbing alcohol.....I'd highly recommend AGAINST that....sure it might (keyword there is might ) work, but the odds of [censored] up your MAF sensor are higher than if you just did the right thing and used the electronics cleaner....
snwbdr is offline   Reply With Quote
Old 03-29-2005, 10:12 PM   #3
Proteus503
Moderator
Great Info! Perhaps even "Sticky" worthy?
Proteus503 is offline   Reply With Quote
Old 03-30-2005, 03:01 PM   #4
AKSHUNJ
AKSHUNJ's Avatar
A lot of people will disagree with me here but if spraying the sensor down with cleaner does not get all the junk off and there's no alternative to having to actually touch the sensor elemetns then I would recommend using one of these. (see below pic) It's called an acid brush and it is made for just this type of thing. I work with electronic components and circuit boards all day long and it is what we use on very delicate parts.
Again, this would be done as a last resort before buying a new sensor.
Old 06-21-2005, 01:38 PM   #5
S-rUNnKiD
Addict
S-rUNnKiD's Avatar
Tacoma: 2001 Tacoma S-Runner BSP
Anyone have an EXACT product name and brand that worked here?
Also, what are some symptoms of a dirty/bad MAF sensor?
S-rUNnKiD is offline   Reply With Quote
Old 06-21-2005, 01:49 PM   #6
AKSHUNJ
AKSHUNJ's Avatar
No exact brand off the top of my head. Symptoms of a dirty TPS include but are not limited to a P0171 code, rough idle, crappy gas mileage, stalling, sputtering under acceleration, etc. etc..
Old 06-21-2005, 01:50 PM   #7
flipside
Enthusiast
flipside's Avatar
Tacoma: 01 Prerunner Dubcab SR5 V6 TRD
How to
flipside is offline   Reply With Quote
Old 06-23-2005, 12:36 PM   #8
Mini98Tacoma
Addict
Tacoma: JACKASS
nice source for info!
Mini98Tacoma is offline   Reply With Quote
Old 06-25-2005, 02:21 AM   #9
ComaJoe
Flying Low
ComaJoe's Avatar
Tacoma: 2003 BSP S-Runner
great info! BUMP for sticky! =)
-ComaJoe
ComaJoe is offline   Reply With Quote
Old 06-25-2005, 06:15 AM   #10
ochizon
back in black (tacoma)!
Tacoma: 1999 2.4L Tacoma, std cab 5spd
Akshun, did you mean to say dirty MAF, or dirty TPS?
ochizon is offline   Reply With Quote
