Whats the difference between a coil over lift and a spacer lift kit? - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > 4x4 and PreRunner Discussion > 4x4/PreRunner Suspension
Old 03-11-2005, 09:42 PM   #1
ToyoTacTRD
Newbie
Tacoma: 2007 toyota tacoma 4x4 trd sport
Default Whats the difference between a coil over lift and a spacer lift kit?
I am going to get a 4 door toyota tacoma 4x4 trd and i was just wondering what the difference is between the coil over lift kit that companies like fabtech offer and the spacer lift kit that companies like revtek offer. I hear alot of people say that the fabtech sucks and that the revtek is better because the cv joint boots wont leak the grease.
ToyoTacTRD is offline   Reply With Quote
Old 03-11-2005, 09:48 PM   #2
sstyota
sstyota's Avatar
Tacoma: 2010 Double Cab SR5 - Magnetic Gray
Default Re: Whats the difference between a coil over lift and a spacer lift ki
Ok, coilovers are brand new coils spings. A spacer lift uses the stock coils by preloading the the springs with usually a polyurethane spacer. You put the spacer on top of the coil. You can go up to 3" on a spacer. Coil overs give a great ride, while spacers stiffen the ride a little. A lot of people like having a stiffer ride...its just ur preference.
A lot of people have the Revtech spacers and like them. Plus, spacers are A LOT more cheaper than coilovers. If u have the money and are looking for comfort...go with coil overs. If u are looking for a cheaper way, go with spacers. Spacers can eventually cause the springs to sag, but this is if u do a lot of hardcore offroading with them.
Check out this sticky post for more info
sstyota is offline   Reply With Quote
Old 03-12-2005, 04:30 PM   #3
matts02taco
Addict
matts02taco's Avatar
Tacoma: 2002 tacoma ext cab v6
spacer are definately cheaper than coilovers... i persoanlly have the toytec 3 inch spacers... i can even tell the diff in the ride and the look it gives is great...mine are aluminum which i think look better than the poly spacers...
matts02taco is offline   Reply With Quote
Old 03-31-2005, 09:49 PM   #4
Wh1te Tac0
Member
Tacoma: trd 02 tacoma
i have a fabtech coilover. the ride is awesome and it will last a long time. mine are adjusted to 3 in. and it loooks great. i think it is definately worth the $1000.
Wh1te Tac0 is offline   Reply With Quote
Old 03-31-2005, 09:59 PM   #5
dcab03
Veteran
dcab03's Avatar
Tacoma: 2003 Toyota Tacoma Double Cab
spacer are definately cheaper than coilovers... i personally have the toytec 3 inch spacers
Like matts02taco said the spacers and diff drop are only gonna cost your about $150 at the most and the Fabtech cost a grand. If you are going to spend that kind of money get some Hoes, Kings or SAWs. I have the Toytecs also and I don't think it rides bad and I saved $850.
dcab03 is offline   Reply With Quote
Old 03-31-2005, 11:02 PM   #6
lifetrddeath
DarkillusionZ
lifetrddeath's Avatar
Tacoma: 2000 PreRunner 2.7L
or you can do both!
lifetrddeath is offline   Reply With Quote
Old 03-31-2005, 11:14 PM   #7
MikesDoubleCab
Mohawk Mike - Super Mod
MikesDoubleCab's Avatar
Tacoma: 01 DCab V6 Prerunner
Default Re: Whats the difference between a coil over lift and a spacer lift kit?
also depends on what you like to do with your truck... i had a coil spacer lift and it was great onroad and slow offroading... threw on the donahoes with deavers and it handles so well hitting whoops and ditches...
MikesDoubleCab is offline   Reply With Quote
Old 11-27-2007, 07:07 PM   #8
mattress8
Newbie
Tacoma: 2008 tacoma TRD SPORT 4x4
"or you can do both! "
I bought some DR coilovers that have 2.5" lift...then If I add 2.5 poly spacer that would give me 5" front lift...? Is that right?....hmm
mattress8 is offline   Reply With Quote
Old 11-27-2007, 08:15 PM   #9
MikesDoubleCab
hope you're kidding... if not, please note that HE was kidding...
Old 11-28-2007, 07:00 AM   #10
sirsaechao
Tacoma: 2002 Toyota Tacoma SR5 TRD 3.4L 4wd ext cab.
Are you *****g retarded? W/o a drop bracket kit you cannot hit 5" with coilovers and spacers.
sirsaechao is offline   Reply With Quote
