Anyone know if thses are worth a damn?
Product Description:
"...natural spectral balance and breathtakingly realistic sound quality." were the words chosen by Car Stereo Review to describe our affordable 5.25-inch 2-way component system. (They also said it was better sounding than a well-known $2000 system.)
The VR component tweeter is a masterpiece of miniaturization and precision German manufacture. The tiny 3/4-inch (19mm) silk dome is fer
uid cooled and housed in a super-compact housing featuring JL AUDIO's exclusive RSR mounting system. A neodymium magnet system allows for a small footprint and maximum installation flexibility of this tiny, but powerful little tweeter.
Premium mylar capacitors are employed to filter the tweeter for uncompromising high-frequency smoothness. The system-specific network is housed in a compact, outboard case and features adjustable tweeter output level and solid-state tweeter protection circuitry.
The woofer element employs a mineral-filled, injection-molded polypropylene cone body with a butyl rubber surround and is designed for smooth, unassisted upper-frequency rolloff that blends seamlessly with the tweeter's output.
Use with outboard amplification for best results.
Features:
2-way System: 5.25-inch (130 mm) Woofer, 0.75-inch (19 mm), Silk Dome Tweeter, Grilles Included
Power Handling: 60W Continuous
Recommended Amp Power: 15 - 100 Watts
Efficiency: 87.5 dB @ 1W/1m
Frequency Response: 63 Hz - 25 KHz ± 3 dB
Frame O.D.: 132 mm
Grille Tray O.D.: 152.6 mm
Magnet O.D.: 70 mm
Frontal Coaxial Tweeter Protrusion: N/A
Frontal Grille Protrusion: 21 mm
Xmax: 3.1 mm
