Center Bore?? Other Toyota Vehicle Wheels? - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > 2wd Discussion > 2wd Wheels and Tires > 1995.5-2004
Old 07-07-2002, 02:52 PM   #1
slamdyota
Addict
slamdyota's Avatar
Question Center Bore?? Other Toyota Vehicle Wheels?
Anyone know the center bore hole on Camry steel factory wheels??, I know the lug pattern is the same. Just wondering if it is big enough for tacos' or if it will have to be drilled out. I will call Toyota in the morning, just if anyone knew now. Thanks. Later...
slamdyota is offline   Reply With Quote
Old 07-07-2002, 04:41 PM   #2
TacomaKevin17
Tacoma: '95 2wd Std Cab Manual Trans
Default Re: Center Bore??
I replied to your PM
TacomaKevin17 is offline   Reply With Quote
Old 07-07-2002, 05:39 PM   #3
TOYDLYF
TOYDLYF's Avatar
Tacoma: 2001 bagged & boosted ,2007 camry xle
i don't think the wheels will work (i've tried to use camry and the new celica wheels) i think it is just a difference between FWD & RWD offsets. but wait , i just remembered that wasn't on my taco, it was on my '87 toyota 2WD that i was trying!!!!! you could go to the parts store and buy a brake rotor from the model you are trying to get the wheels from and see if it matches up to either your hub and rotor set up or just pick up a rotor for yours too and compare the bolt patterns on the backside, then just neatly put the un-used rotors back in the box and make a return to the parts store!!!!!
TOYDLYF is offline   Reply With Quote
Old 07-07-2002, 06:27 PM   #4
pucancakes
Grand Tacoholic
Tacoma: crashed
new celica wheels wont work because the lug pattern is different. 5x100
pucancakes is offline   Reply With Quote
Old 07-07-2002, 07:08 PM   #5
slamdyota
Addict
slamdyota's Avatar
thanks kevin.....bolt pattern is the same, but bore is way to small
Old 07-08-2002, 07:50 PM   #6
Aldo
Aldo's Avatar
Tacoma: 97 Tacoma 2rz
Well, the Lexus IS300 wheels I have on my Taco, had a center bore of 60.1mm. I had them enlargened to 68mm. But I was under the impression that all 5x114.3mm wheels had the same center bore of 60.1mm.
Aldo is offline   Reply With Quote
Ford Center bore? MillerTime Off Topic 3 04-11-2006 12:17 AM
FYI: SR Market Watch: Feb 20 2006 Enola Gaia S-Runner Talk 0 02-20-2006 07:42 AM
What other Toyota steering wheels fit? veinyboto Interior/Audio/Electronics 1 04-02-2003 04:59 PM
Center Bore Enlargement texastaco Off Topic 14 06-07-2002 07:34 PM
