water dripping from exhaust tip/with white smoke - CustomTacos.com Forum
Old 03-29-2004, 01:45 AM   #1
Sauron64
Tacoma: 2003 S-Runner
Default water dripping from exhaust tip/with white smoke
i started noticing it last week. although it could have been going on for a long time. i cant think of any reason why its doing this, but there is water slowly dripping out of my exhaust tip when i start it up. i havent checked to see if happens all the time yet, but i noticed it again last night and need to take of it. any thoughts as to what it is? oh also, there is a white/grey smoke coming out last night too. i dont think it was cold enough to do that on its own. whats that all about?
Sauron64 is offline   Reply With Quote Quick reply to this message
Old 03-29-2004, 04:51 AM   #2
ComaJoe
Flying Low
ComaJoe's Avatar
Tacoma: 2003 BSP S-Runner
Default Re: water dripping from exhaust tip/with white smoke
not sure about the smoke but I'm pretty sure the water drippage is normal... it's just condensation being blown out of the exhaust piping. it only happens first thing in the morning, right?
-ComaJoe
ComaJoe is offline   Reply With Quote Quick reply to this message
Old 03-29-2004, 06:51 AM   #3
djnarush
Tacoma: 98 5spd X cab
white/grey smoke?
do u notice if.. or what it smells like...
smoke like that usually means your burning coolant...
check the plugs to see what they look like
djnarush is offline   Reply With Quote Quick reply to this message
Old 03-29-2004, 08:22 AM   #4
**DONOTDELETE**
Guest
Posts: n/a
the water and smoke are both completely normal as long as they stop once everything gets up to temp. It all has to do with condensation getting blown out, and vapor being expelled. Once your taco is at running-temp it should stop. If not, there's another problem, perhaps the coolant issue previously mentioned.
Old 03-29-2004, 09:08 AM   #5
redrunner
slow poke
redrunner's Avatar
Tacoma: '01 S-Runner
yeah, the water is definately normal. condensation gets all up in your piping overnight with the dew factor and such. Actually potroast pretty much covered it, it's normal unless its absolutely constant.
now, go start playing "how far can 5,200 rpms shoot this water out my tailpipe..."
redrunner is offline   Reply With Quote Quick reply to this message
Old 03-29-2004, 10:10 AM   #6
TOYDLYF
TOYDLYF's Avatar
Tacoma: 2001 bagged & boosted ,2007 camry xle
that is your catalytic converter at work
it is turning monoxide into hydrocarbons
w/o it (cat) black soot would come out...and would smell BAD
TOYDLYF is offline   Reply With Quote Quick reply to this message
Old 03-29-2004, 10:22 AM   #7
fabtaco
Probation
It's not so bad once you get used to the fumes
fabtaco is offline   Reply With Quote Quick reply to this message
Old 03-29-2004, 10:30 AM   #8
redrunner
slow poke
redrunner's Avatar
his reason sounds way more scientific than mine, so im going to go with dan and revoke my statement.
Old 03-31-2004, 01:10 PM   #9
Proteus503
Moderator
I hate to be the bearer of bad tidings, but I'm having a similar problem and I can tell you with 90% certainty that it's a bad HEAD GASKET! Is your truck kinda hard to start? Are you having any mis-fire issues / CE Lights? Try this... the next time you go out for a drive... drive it for like, 15 minutes, get the temp gauge to read normal / midway. then pull over, turn off the truck, and let it sit for 1 minute. then restart the truck and check for white smoke. This'll tell you if your head gasket is leaking... cuz if it is, white smoke will pour out've your exhaust when you restart the engine while the catalitic converter is hot. coolant will squirt through the exhaust pipes and vaporize through the hot catalitic causing a cloud of white steam to blow out've your exhaust after a hot start. I'm having this issue and I'm replacing my headgasket next week. You might also want to do a compression test since you have a v6 (two heads) to figure out which side needs the head gasket and which doesnt.
Proteus503 is offline   Reply With Quote Quick reply to this message
Old 04-01-2004, 05:02 AM   #10
Felixatvtc
Felixatvtc's Avatar
Tacoma: 09 ex-cab 4x4
Thanks for the informative post Colin. I think my supra might have a BHG. I'm going to test this out tonight
Felixatvtc is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
