3 wheel motion - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > 2wd Discussion > 2wd Suspension
Old 02-08-2004, 01:19 PM   #1
Aktoy
Aktoy's Avatar
Tacoma: 94 pickup
Default 3 wheel motion
I saw on the techidemics streettrucks, some dude 3 wheelin' around a corner. I have been told all you have to do is drop your rear corner and hit a turn at a decient speed and the front corner will come up.
Is this true? and if it is how bad is in on your rims? (scuffs, beadbreakin)
Aktoy is offline   Reply With Quote Quick reply to this message
Old 02-08-2004, 02:41 PM   #2
OGSpacePimp
Grand Tacoholic
OGSpacePimp's Avatar
Tacoma: '99 2wd Extra-cab SR5, 2.4L 5spd
Default Re: 3 wheel motion
you need to have quite a bit of weight in the rear on a pickup to hit front side 3-wheel, shouldn't be bad on wheels or tires too much
OGSpacePimp is offline   Reply With Quote Quick reply to this message
Old 02-08-2004, 02:53 PM   #3
lowtoydude
Probation
Tacoma: 93 toy p/u
probably has a strap on that corner keeping it at a certain drop the wheel can go. if you had air cylinders you could do it. i know if u tie down 1 side of the rear and i dunno, arrange the corner you could park it dogleg...i tried, but i get crappy lift so it didnt work too well haha.
lowtoydude is offline   Reply With Quote Quick reply to this message
Old 02-08-2004, 05:07 PM   #4
Aktoy
Aktoy's Avatar
Tacoma: 94 pickup
I guess I will just have to rock the dogleg
Old 02-08-2004, 06:19 PM   #5
tacomadanny331
Addict
Tacoma: 02 single cab toyota tacoma
if you use those air struts i geuss thats wat there called in sted of air baggs can you pop a 3 wheel?
tacomadanny331 is offline   Reply With Quote Quick reply to this message
Old 02-08-2004, 06:45 PM   #6
AsIaN tAcO
Grand Tacoholic
AsIaN tAcO's Avatar
Tacoma: 2007 RR XRunner
I think i have this DVD, if this is the video where the taco is going in circles i have it. Yeah 3 wheel motion is pretty cool looking on a turn.
AsIaN tAcO is offline   Reply With Quote Quick reply to this message
Old 02-08-2004, 06:50 PM   #7
TRD4UNME
Enthusiast
Tacoma: 1999 green 2.7 prerunner
The old 1968-76 BMW 2002's used to lift a rear wheel in a corner.
Anyone with a NITRO R/C car can tell you how to do it. I believe you need to make the front suspension very soft and the rear stiff to lift a rear tire. So the opposite would lift the front.
TRD4UNME is offline   Reply With Quote Quick reply to this message
Old 02-08-2004, 07:02 PM   #8
MellowD
MellowD's Avatar
Tacoma: 98 Tacoma 2wd & and a 98 Tacoma 2wd
ummmm ok it depends on what psi you are running. you may need to run nitrogen in order to get the lift. just lock all 4 corners up then drop 1 and you should be able to roll on 3 wheels.
MellowD is offline   Reply With Quote Quick reply to this message
Old 02-08-2004, 07:05 PM   #9
TRD4UNME
Enthusiast
my point is...I believe you need to make the front suspension very soft and the rear stiff to lift a rear tire. So the opposite would lift the front.
Old 02-08-2004, 08:53 PM   #10
pr1mo360
Veteran
Tacoma: 97 std cab
before turning a hard left u have the front left corner down all the rest up then as you turn hit the left front corner up and the right rear down and it will get the wheel up pretty high
pr1mo360 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
