strange idling when at a stop sign - CustomTacos.com Forum
Old 01-22-2004, 09:02 PM   #1
Acidpain
Member
Default strange idling when at a stop sign
Several times when comming to a stop and after stoping the idle seems to go real low like it wants to stall out, but i give it gas and it seems to be back to normal. its a 2004 manual 2.4L truck. It only did it a several times and was wondering if any of yall ever had that problem and if so, what causes it? or is it a normal behaivor of this type of truck? Thanks
Acidpain is offline   Reply With Quote
Old 01-22-2004, 11:16 PM   #2
Proteus503
Moderator
Default Re: strange idling when at a stop sign
mine does that every once in a while... usually when the weather makes a drastic change... like today: it was cold and dry this mornin, but when i fired up the truck to go home after work, it was warm and humid. had a low, rough idle when i put the truck into neutral at stops. The ECU just needs to adjust to changes in the weather.
Proteus503 is offline   Reply With Quote
Old 01-22-2004, 11:40 PM   #3
Kgrgunman
The Stig
Kgrgunman's Avatar
Tacoma: '91 regular cab, 4x4, pre-taco and '05 X-Runner
next time it does that, don't give it gas, and see if it stalls and kills the motor or if it brings it's self up, with u doing nothing, i'd say if it stalls, take it back to toyota, if it recovers it's self with u doing nothing, it's fine.
Kgrgunman is offline   Reply With Quote
Old 01-23-2004, 03:17 AM   #4
1997Taco
Addict
Tacoma: '97 XtraCab
mine does the same thing, it'll go from like 750/1000 RPM(whatevers normal) down to like 500 and the lights will dim a lil' and then b4 I know it, it jumps back up, and then the light changes, lol. I think it's normal man, but I'll say it til Wyotech get's back to me, I ain't a mechanic(yet).
oh yeah, btw Kgrgunman, anything's faster than a speeding Kia, lol
1997Taco is offline   Reply With Quote
