Aluminum flywheel, Map ECU2 piggyback, Turbonetics turbo - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > The Marketplace > For Sale > Parts and Accessories
Old 02-20-2013, 09:28 PM   #1
TheTacoKid
Enthusiast
TheTacoKid's Avatar
Tacoma: Sold the Taco, working on my Datsun Roadster
Default Aluminum flywheel, Map ECU2 piggyback, Turbonetics turbo
Bought this from another member here less than month ago, and I decided to go with a different engine instead.
Map ECU2 piggyback: $300 (read more about it @ urdusa.com)
Fidanza aluminum flywheel with extra buffer plate: $200
Turbonetics T3 turbo ( w/ extra parts for rebuild): $350
2rz T3 Turbo manifold: $150
May consider trades for these RWD sr20det parts:
  • Chipped ECU (Nistune preferred)
  • injectors (440 or larger)
  • Harnesses
  • CAS
  • Coilpacks w/ sub harness
TheTacoKid is offline   Reply With Quote
Old 02-25-2013, 07:40 AM   #2
kurt4726
Newbie
Tacoma: 2002 Toyota Pickup 4x4 3rz-fe
Default Re: Aluminum flywheel, Map ECU2 piggyback, Turbonetics turbo
I'm interested in the turbo manifold if there are no cracks. I might also be interested in the turbo if you could post photos of it or send to my e-mail. Do you have the specs on the turbo? I'm looking for something similar to a garrett GT3071R Cold side: .60 A/R 4" inlet Hot side: .63 A/R. I think turbonetics' equivalent would be a T3/T04E Cold side: .60 A/R 4" inlet Hot side: .63 A/R.
kurt4726 is offline   Reply With Quote
Old 02-28-2013, 12:12 PM   #3
TheTacoKid
Enthusiast
TheTacoKid's Avatar
Manifold is sold.
1998 3RZ S/C piggyback: FTC1-E vs MAP ECU2? mosk Performance 10 04-28-2011 09:48 AM
Fidanza Aluminum Flywheel!!! Paradise Racing Parts and Accessories 1 06-23-2008 12:19 PM
13-pound Aluminum Flywheel for 5VZ! LCEpower Vendor Marketplace 0 04-02-2008 01:00 PM
2.7 Aluminum Flywheel??? Paradise Racing Performance 21 01-03-2006 07:03 PM
aluminum flywheel 3Point4Tacoma Performance 6 09-22-2003 10:30 PM
