tire size help - CustomTacos.com Forum
Old 02-17-2013, 02:44 PM   #1
cadman33619
Member
cadman33619's Avatar
Default tire size help
time to replace the tires ....
i'm a little confused though...from what i read, the original tires are 225/75/r15. what i have on there now are 265/65/r17 and i'd like to keep the same size. shopping online at sears i get a message that the size i have now will not fit. obviously they do bc i have them now......
i dont want to get tires that are visibly smaller (in fact i'd like them a lil bigger). can someone tell me what tire sizes will fit and maybe recommend a site that has better prices?
fyi...rim size (diameter) is 18.5"
thanks
cadman
2004 PreRunner; 2WD, Automatic, 102k miles
Switchback LED signal light/DTRL mod looks great
Cupholder LED mod looks awsome.
cadman33619 is offline   Reply With Quote
Old 02-17-2013, 02:48 PM   #2
purplepoison
Veteran
purplepoison's Avatar
Tacoma: 1997, Toyota Tacoma 2.4L L4 Auto, DLX Ext.
Default Re: tire size help
Big o tires website or discount tires website, the size ur running should be fine and by larger do u want wider or taller? For looks or offroad use?
Sent from my SGH-T989 using AutoGuide.Com Free App
purplepoison is offline   Reply With Quote
Old 02-17-2013, 03:55 PM   #3
Mad Maxx
Enthusiast
Mad Maxx's Avatar
Tacoma: 2001, 4X4 3.4L
Also check out tire rack dot com they have good prices on tires & also on wheels.
Mad Maxx is offline   Reply With Quote
Old 02-17-2013, 04:29 PM   #4
cadman33619
Member
thanks for the replies...
i'm going for looks, not offroad. i'd lile them a little taller. i plan on getting wheel spacers to push them out just a little.
i'll def try those sites
thanks
Old 02-17-2013, 04:46 PM   #5
Mad Maxx
Enthusiast
Mad Maxx's Avatar
If you are thinking about getting different wheels? You can get them in a negative offset & that will make them fit so that they stick outside of your fenders. I have a 2001 Tacoma & the stock offset is +12mm on them which keeps them inside the fenders. Hope that helps.
Old 02-17-2013, 07:57 PM   #6
preybird1
Member
preybird1's Avatar
Tacoma: 2004 tacoma trd 3.4l v-6
I have a 04 taco with 3" adjustable bilstein struts and taller shocks in the rear with add a leaf springs. I have p2657017 right now and i like them just fine. If you put in a 2" strut riser plate they will not rub the factory fenderette. Every size you go up 65-70-75 is an inch gain in diameter for each size. 265-275-295 is your width. I buy new tires every year and i sell my tires before the 1st 3rd is worn off of them. I have literally tried 7 different tire brands\styles in the last 3 yrs. I love fresh tires all the time!! And since i sell tires it cost me nothing and usually i make a $100 bucks doing it. i just put on some nitto terra grapplers on friday! I just sold my old falken high country's for $500.00 The new tires cost me $111.00 each at cost. retail $179 each. So im in for $444 and a $66 profit off this set.
preybird1 is offline   Reply With Quote
tire size help Jdawgjax31 2005+ 0 06-12-2008 04:53 PM
? on tire size fire931 2005+ 6 11-24-2007 12:38 PM
which rim size tire size? seamoose213 4x4/PreRunner Wheels and Tires 4 03-01-2007 09:53 PM
Lift Size And Tire Size 1luckyman 2005+ 3 02-22-2007 07:00 AM
new tire size? SkydTRD 4x4/PreRunner Wheels and Tires 6 12-04-2003 01:07 PM
