Addco vs. Hellwig sway bars - Page 2 - CustomTacos.com Forum
Old 11-01-2003, 07:37 PM   #11
EdCal
Addict
EdCal's Avatar
Tacoma: 2002 DubCab PreRunner
Default Re: Addco vs. Hellwig sway bars
pros and cons of rear Hellwig and Addco:
Addco larger diameter bar
Hellwig bolts on, Addco need to drill holes in frame
Hellwig bar is cold formed Addco is bar heat formed
either one is better then none
EdCal is offline   Reply With Quote Quick reply to this message
Old 11-01-2003, 08:38 PM   #12
trdtoytaco
Enthusiast
Tacoma: 00' 2.4l 2wd standard cab
I have an Addco for sale, never used - $100
Hmmm...tempting, but I'll have to save up till after I go to Vegas this coming up weekend for SEMA. I'll pm ya if I decide to go with Addco, though I like the bolt on factor of Hellwig. Decisions...decisions....
trdtoytaco is offline   Reply With Quote Quick reply to this message
Old 11-02-2003, 02:30 AM   #13
ThumpinToyTaco97
Member
Tacoma: 1997 Toyota Tacoma -Extended Cab
hey buddy, you can order it from j.c. whitney and by the way i have the
hellwig rear sway-bar on my taco-97. works hella good, especially taken
it to the maximum on the cornering in the turns over here by twin peaks
in san francisco! hope you find your hellwig rear sway-bar.
ThumpinToyTaco97 is offline   Reply With Quote Quick reply to this message
Old 11-02-2003, 06:22 AM   #14
S-Dad
Addict
Tacoma: 2012 Tundra Crewmax. '04 Dub Cab - sold, '01 S Runner - sold
I'll be honest with you - if you're lowered more than 2 inches you should go with the Hellwig. The Addco installs well for stock or even lifted trucks.
S-Dad is offline   Reply With Quote Quick reply to this message
Old 11-02-2003, 08:58 AM   #15
ComaJoeWork
Member
Tacoma: http://www.customtacos.com/ubbthreads/showprofile.php?Cat=&User=709
S-Runner Dad: PM sent
ComaJoeWork is offline   Reply With Quote Quick reply to this message
Old 11-02-2003, 11:10 AM   #16
trdtoytaco
Enthusiast
I am lowered about 5" so maybee Hellwig will be my choice. I also drag race alot too, so the softer hellwig bar will retain the weight transfer I need for traction.
Old 11-02-2003, 09:57 PM   #17
Chris98
Addict
Chris98's Avatar
Tacoma: 05 Cooper S
Anyone know where i could get a Hellwig rear sway bar for a good price?
Chris98 is offline   Reply With Quote Quick reply to this message
Old 11-03-2003, 08:47 AM   #18
ToyComa
Tacoma: 1st autox/drift Tacoma in New Jersey
this is with a hellwig. do you take your truck to the max and have it do this???? that is pushing it to the limit. on the street it may seem like it helps a lot but take it to do some auto cross and you soon find it isnt doing much. i need stiffer front springs now. TRD how did you lower your truck and what manufacturers are the parts from??
ToyComa is offline   Reply With Quote Quick reply to this message
Old 11-03-2003, 06:43 PM   #19
trdtoytaco
Enthusiast
[/qoute] TRD how did you lower your truck and what manufacturers are the parts from??
[/QUOTE] Flipped ball joint and Eibach's, though I want someting stiffer w/same drop. Mono leaf w/1" block all on Tockico's. I'm also looking to get KYB short struts. I push it hard on the street, like that pic, but not that often. I really want to autocross but my tires suck a$$, so I'm looking at a new set up for that.
Old 11-03-2003, 07:50 PM   #20
ToyComa
[/QUOTE] i wonder how much more i could go with the coil springs before the ride became to harsh? does anybody know the rating on the stock ones?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
