Ifs lockrightlocker work in the rear of my taco? - CustomTacos.com Forum
Old 01-23-2013, 02:20 PM   #1
donutman126
Member
Tacoma: 1997 taco 5 lug
Default Ifs lockrightlocker work in the rear of my taco?
I know someones with a diff housing out of a 1990-1995 ifs truck. Will the lockright locker and 4.56 gears drop right into my 5 lug taco rear end? Thanks
donutman126 is offline   Reply With Quote
Old 01-23-2013, 03:37 PM   #2
Chris D.
ADMlNAHATER
Chris D.'s Avatar
Default Re: Ifs lockrightlocker work in the rear of my taco?
suggestion.. Update your profile to include (5-lug)
Are you lifting your 5 lug on some 38"+ tires?
What size tires are you going to run with this setup?
Old 01-23-2013, 08:27 PM   #3
donutman126
Member
Going to put the truck on 31s, im mainly buying this for the locker and will prob try to find 4.10s for gears
Old 01-24-2013, 08:34 PM   #4
rokblok
Newbie
If its an 8" differential, it should work. But I'm not sure about 2wd, 5 lugs.
rokblok is offline   Reply With Quote
Old 01-24-2013, 11:23 PM   #5
donutman126
Member
8" diff? Both my rear 5 lug 7.5 and the toyota 4x4 ifs front end is 7.5 im pretty sure the gears and lockright locker are interchangable?
Old 01-25-2013, 05:39 AM   #6
rokblok
Newbie
OP didnt specify front or rear that the Lockright was out of.... I just assumed rear. My mistake.
ECGS says it should fit. Same part number for all 7.5" diffs. Doesn't matter front 4wd, or rear 2wd.
I'm not allowed to post the link yet, but check out Eastcoastgearsupply.com
Old 01-25-2013, 06:54 AM   #7
HaVoCX
Enthusiast
HaVoCX's Avatar
Tacoma: 1996 3RZ 4x4
Im pretty sure theres a diff in the gearing tho. Thats why detroit lockers offer a "7.5
In the rear (IRS) and front (IFS).
Btw, im selling my detroit lsd locker 7.5 IRS, New in box, for a stoner special of only 420 shipped.
http://www.CustomTacos.com/forum/sho...d.php?t=157543
Good luck buddy
HaVoCX is offline   Reply With Quote
will front ifs gear work in the rear of mt 5 lug? donutman126 1995.5-2004 5 01-01-2013 12:51 PM
rear brakes work well when under load adklee2137 1995.5 - 2004 18 07-25-2008 01:19 AM
Will 285 work with stock ride height, in the rear?? Tillers_Rule 4x4/PreRunner Suspension 4 06-11-2008 01:15 AM
rear end work ADRay 1995.5-2004 1 10-03-2007 02:28 PM
my rear sub quit work, rednecktaco Interior/Audio/Electronics 18 09-16-2004 03:35 PM
