Non tacoma related. 94 camry tranny - CustomTacos.com Forum
Old 01-20-2013, 09:32 PM   #1
sportsman1539
Addict
sportsman1539's Avatar
Tacoma: 96 Tacoma LX 2.4L 5-speed extended cab.
Default Non tacoma related. 94 camry tranny
I figured I could ask this question on a forum I'm already a member of instead of joining a Camry forum. Its a very general question that could apply to any vehicle. I have a 94 automatic Camry that has been sitting for almost a year. I jumped it off and it started immediately. Only problem is when I shift it in drive or reverse, it never engages. The shifter moves but it never engages. Prior to it sitting for a year I never had any transmission issues. I checked the fluid and I didn't see any on the dipstick. I was on a slight incline so that could be part of the problem. If in fact it is out of fluid, should filling it up fix this problem? Btw the shifter cable appears to be working properly
sportsman1539 is offline   Reply With Quote
Old 01-21-2013, 08:21 AM   #2
blackedout_taco_stidham
Grand Tacoholic
blackedout_taco_stidham's Avatar
Tacoma: 2000 Reg Cab 5-Speed Turbo
Default Re: Non tacoma related. 94 camry tranny
i say get the car level (as much as possible). Check the fluid level again, if its not right, then add until it is right. Sounds like a simple fix to me since you said there wasnt any on the dipstick.
Remember when adding fluid to the tranny, transmission fluid EXPANDS when it gets hot, so be careful not to over fill it. There should be two marks on your dipstick, one for cold reading and one for hot reading. Fill to the corresponding fluid level. I recommend leaving the car off and letting it cool, then fill it to the cold reading line. Then start the car and let the engine get to operating temps, then check the fluid again WHILE THE ENGINE IS RUNNING. Checking the fluid while its running will get you the most accurate transmission fluid level reading.
I hope this helps and you dont have a serious tranny problem, looks like you might have a leak, so remember to keep an eye on it.
QA1's and BJ Flip up front, Drop leafs and beefed blocks out back, Celica Seats, decent sound system w/some 10's. Boost Brigade Since APR 2012, Member of the NO BOV Club!...CH-CH-Ch-Ch-ch-ch
blackedout_taco_stidham is offline   Reply With Quote
Old 01-21-2013, 09:02 AM   #3
sportsman1539
Addict
Cool man! Thanks for the reply. It won't even engage in neutral so I can't get it off of the incline. So I'm thinking of draining it, adding 2 quarts of fluid(recommends 3.5) hoping it engages so I can get it on flat ground, and topping it off
Old 01-21-2013, 09:33 AM   #4
Grand Tacoholic
If the manual says It holds 3.5 quarts then id put 3.5 in it, you dont want to starve an automatic especially. Heat means death for autos, and fluid helps dissipate that heat.
Old 01-22-2013, 09:21 AM   #5
sportsman1539
Addict
Put transmission fluid in it and it ran great! Moderators feel free to delete this non Tacoma related thread. Thanks!
Old 01-22-2013, 12:25 PM   #6
Grand Tacoholic
glad the fluid is all it needed...man i hate automatics...
Old 01-22-2013, 12:44 PM   #7
sportsman1539
Addict
Yea me too. My 5 speed 96 taco has 240,000 miles on it and I have yet to touch the tranny fluid.
Brake Problem..Not Tacoma Related But Need Some Help. STOCKTRD Maintenance 6 03-22-2009 12:10 PM
links to tacoma related websites kevin_d_king Customtacos AutoGuide Forum Support / Help 7 03-05-2008 08:44 AM
Clutch-Related Noise (Underneath Truck / Tranny) (2005+) vtechthis 2005+ 3 02-19-2006 02:29 PM
non tacoma related stuff for sale celticcowboy1119 Non-Automotive Items 64 10-11-2005 07:18 AM
Not performance related, just sanity related........door/key chime M5James Performance 14 07-31-2003 07:29 AM
