How do you connect amp to 01 xtracab rear speakers? - CustomTacos.com Forum
Old 01-06-2013, 06:37 PM   #1
rmg
Newbie
Default How do you connect amp to 01 xtracab rear speakers?
Hello,
I have a 2001 Tacoma Xtracab and a Kicker Hideaway (powered sub).
If I follow the instructions on this website for speaker removal:
Do I need to access both rear speakers to connect to my sub/amp? or can I just connect it to one?
Will there be a wire that can be used for auto turn-on?(won't use battery power when vehicle turned off)
Any help is greatly appreciated!!
Thanks!
rmg is offline   Reply With Quote
Old 01-06-2013, 07:09 PM   #2
purplepoison
Veteran
purplepoison's Avatar
Tacoma: 1997, Toyota Tacoma 2.4L L4 Auto, DLX Ext.
Default
You can hook ot up to the power antenna wire on the stereo harness thats what i do
Sent from my SGH-T989 using AutoGuide.Com Free App
purplepoison is online now   Reply With Quote
Old 01-06-2013, 07:16 PM   #3
rmg
Newbie
Default Re: How do you connect amp to 01 xtracab rear speakers?
Where exactly is the power antenna wire?
Do you need to remove the stereo to get to it?
Thanks
Old 01-06-2013, 08:43 PM   #4
Yodaforce
Grand Tacoholic
Yodaforce's Avatar
Tacoma: 2001 S-Runner boosted with alot of URD parts.
You can remove the head unit to do everything you need to do (it's MUCH easier than removing the rear panels to get to the speakers). You can either wire your sub amp to the rear speaker outputs on the back of the head unit through each speaker wire and run the lines back to wherever you choose to mount the amp, or, you can wire in a line converter (http://compare.ebay.com/like/3305366...Types&var=sbar) to run RCA cables to the amp.
The power antenna wire (usually blue) is in the harness behind the radio as well.
Diverse-Customs.com
Yodaforce is offline   Reply With Quote
Old 01-07-2013, 07:14 AM   #5
Enola Gaia
Enola Gaia's Avatar
Originally Posted by purplepoison View Post
You can hook ot up to the power antenna wire on the stereo harness thats what i do ...
Originally Posted by rmg View Post
Where exactly is the power antenna wire? Do you need to remove the stereo to get to it? ...
There is no power antenna connection on a 2001. The power antenna was discontinued by the time the 2001 - 2004 generation came out.
Old 01-07-2013, 07:24 AM   #6
Enola Gaia
Enola Gaia's Avatar
Here (attached) is the 2001 radio / stereo wiring diagram. According to the Kicker manual available online at:
http://www.kicker.com/sites/default/...%20Rev%20M.pdf
... you'll need to splice your quick-connect harness to the factory head unit's speaker lines. You should be able to use either front or rear speaker lines, as long as you splice into both right and left channels.
The Kicker manual lists the following layout for the sub unit's speaker lines:
Quick-connect harness audio inputs:
White = Left +
White/Black = Left –
Grey = Right +
Grey/Black = Right –
Old 01-07-2013, 07:59 AM   #7
Yodaforce
Grand Tacoholic
Yodaforce's Avatar
Ok. So I guess you can easily tap into the 12v power outlet for an amp trigger/remote turn on since they only have voltage when the ign is on.
Diverse-Customs.com
Old 01-07-2013, 09:15 AM   #8
Chris D.
ADMlNAHATER
Chris D.'s Avatar
Is this some sort of specific fitment tacoma kicker setup?
Old 01-07-2013, 11:02 AM   #9
Yodaforce
Grand Tacoholic
Yodaforce's Avatar
Looks like one of those "under seat" type subs. More for driver "feel" than noise.
http://www.kicker.com/hideaway
Diverse-Customs.com
Old 01-07-2013, 02:11 PM   #10
rmg
Newbie
Thanks for all the help!
If I ended up getting a new head unit with rca output, could I simply connect my sub to that instead of splicing wires? And could I just plug the factory wiring harness into the new head unit?
Re: Whats Sizes Speakers are in a 2001 Tacoma XtraCab? spookey Interior/Audio/Electronics 1 03-24-2008 07:21 PM
tip for foggy rear windows in xtracab Bhavesh Interior/Audio/Electronics 10 12-01-2007 12:29 AM
Speakers and head unit - '03 Xtracab nostalgia Interior/Audio/Electronics 0 06-10-2007 07:36 PM
locking rear diff for 2.7L '01 PreRunner Xtracab? El Taco Blanco Off Road 7 09-25-2006 07:32 PM
Overhead Speaker Rack (XtraCab Rear): Ecoustics Enola Gaia Interior/Audio/Electronics 9 05-07-2006 07:54 PM
