How wide is a 91 pre-taco 5lug rear end? - CustomTacos.com Forum
Old 01-02-2013, 09:13 AM   #1
Chris D.
ADMlNAHATER
Chris D.'s Avatar
Default How wide is a 91 pre-taco 5lug rear end?
I founda 91 pretaco 5lug rear end complete drum/drum for sale locally but wasn't sure how wide it is compared to a tacoma rear end.
Anyone know if they have the same hub diametor for wheels? 67.1 tacoma?
Will all the taco hardware/3rd swap right over?
Thanks,
Old 01-02-2013, 12:22 PM   #2
hamish_18
Enthusiast
Tacoma: 1999 Toyota Tacoma Xtracab 2wd
Default Re: How wide is a 91 pre-taco 5lug rear end?
I know the 3rd will swap to ours. they are all 7.5 in rear ends. overall length though? not sure about that.
1999 Toyota Tacoma xtra cab 2rz boosted by Garrett
270hp/300tq @ 14.7psi. Dyno Run
300hp/332tq @ ~18 psi & meth injection
hamish_18 is offline   Reply With Quote
Old 01-02-2013, 12:43 PM   #3
tacomatic1
tacomatic1's Avatar
I thought they were ~3" narrower WMS to WMS but someone correct me if I am wrong.
Old 01-02-2013, 01:17 PM   #4
Chris D.
ADMlNAHATER
Chris D.'s Avatar
I remember there being a pretaco rear end thread with specs per year but cant find em.
If it turns out to be 3" narrower, thats another 1 1/2" more drag radial that I can stuff back there.
Need more tire and tuck, planning on pulling my bedsides out another inch..
Old 01-02-2013, 01:35 PM   #5
donutman126
Member
Tacoma: 1997 taco 5 lug
Your not worried about breaking ur 7.5 R/P or axle shaft?
donutman126 is offline   Reply With Quote
Old 01-02-2013, 03:29 PM   #6
tacomatic1
tacomatic1's Avatar
I'm not. Been pushing 15psi on it for a bit. I haven't done too many hard launches though. If it breaks, I'll change it.
Old 01-03-2013, 01:19 PM   #7
Chris D.
ADMlNAHATER
Chris D.'s Avatar
Nope.. 300ish whp isn't going to kill anything if I know of another 7.5 rear end seeing 600whp with an additional 100hp shot that pulls the front end off the ground..
Old 01-04-2013, 09:46 AM   #8
Speed Freek
Tacorvette enthusiast
Speed Freek's Avatar
With aftermarket axles and a locker (Ochizon)
Just wondering why the shorter axle, why dont you just get a different offset set of wheels? Or are you shooting for the deep dish wheel look that requires a shorter axle length?
I need to do something before I turbo the V8, even now if I stab the throttle it lights em up, that torque from the LS1 is pretty good. Gonna need some 10"+ wheels back there.
BOOST BRIGADE I fabricate custom parts: HEIM STYLE STRUT RODS, FORWARD FACING INTAKE MANIFOLDS, and TRACTION BARS (5 LUG) contact me for more info @ www.Speed-freek.com or just PM me here THANKS!
Former Lexus / Toyota tech
Speed Freek is offline   Reply With Quote
Old 01-04-2013, 10:03 AM   #9
Chris D.
ADMlNAHATER
Chris D.'s Avatar
I'm getting a narrower housing for 2 reasons..
Tacoma 2wd 5 lug rear ends never come up for sale, 2wd is just not popular in the snow belt.
Also, I talked to strange a month ago and they make a direct fit axle setup for the 94 and older rear ends.. I have the Richmond Lockright in there now.
I also found a few disk brake rear ends for the pretaco axles, no need for c clip eliminators if you have disk brakes
I dont want to buy another set of wheels and Im limited to offsets/widths with the style I have..
Old 01-04-2013, 10:38 AM   #10
Speed Freek
Thorough answer, lol. Got it. Figured there was a method to your madness..
01 5lug rear axle tacorunner87 Parts and Accessories 0 04-25-2009 10:31 PM
01 5lug rear axle tacorunner87 1995.5 - 2004 7 02-23-2009 06:32 PM
XR With wide rear tires XtotheGSXR 2005+ 10 04-04-2007 06:41 PM
2wd 5lug rear end NVTACO Parts and Accessories 1 10-22-2005 07:00 PM
WIDE REAR VIEW MIRROR SD TACO Interior/Audio/Electronics 5 12-04-2004 05:23 PM
