Gas spraying from fuel lines! *HELP* - CustomTacos.com Forum
Old 12-23-2012, 02:14 AM   #1
2000blacktaco
Enthusiast
2000blacktaco's Avatar
Tacoma: 2000 toyta tacoma
Default Gas spraying from fuel lines! *HELP*
Hello. I just went to turn my truck on and noticed a hissing sound. I swore it was static coming from my speakers because it sounded like static but the volume was off. I got out of the truck and quickly smelled gas and saw a huge puddle under my truck. It was a very strong, fine mist. DAMNIT! So I let it dry a little and jacked it up. After it was dry I turned the truck back on for a split second then turned it off. I did this so I could then get under and see what was wet. Saw a WET flare fitting on a fuel line about one foot away from the top of the fuel pump. I narrowed it down to that fitting or the one foot bent tube connecting the fuel pump to the fuel line. I dont know if its the return or the in line. I took a picture of the fitting which is right next to the gas tank, roughly a foot away from the fuel pump like I said. Any CLUE where I should start? Not even sure what that tube is called going into the fuel pump.
MUST TURBO
2000blacktaco is offline   Reply With Quote
Old 12-23-2012, 03:09 AM   #2
2000blacktaco
Enthusiast
Default Re: Gas spraying from fuel lines! *HELP*
MUST TURBO
Old 12-23-2012, 04:47 AM   #3
cmcpher
Addict
cmcpher's Avatar
Tacoma: 93 Turbo Pickup/ 97 Tacoma 4x4/ 04 Tacoma
Have you already tried tighten the flare nuts?
On the prowl
cmcpher is offline   Reply With Quote
Old 12-23-2012, 04:51 AM   #4
2000blacktaco
Enthusiast
No...I don't have flare nut wrenches I don't want to screw them up. Last time I drove I wasn't spraying any gas so I doubt it's a loose connection. It was extremely cold when I went to start my truck too. What is that hose called anyway?
MUST TURBO
Old 12-23-2012, 04:58 AM   #5
cmcpher
Addict
cmcpher's Avatar
Eh you would be surprised how it doesn't appear to be loose but actually is loose especially on the high pressure side of the fuel system. Some refer to it as the main fuel line.
On the prowl
Old 12-23-2012, 05:06 AM   #6
2000blacktaco
Enthusiast
OK Ill see if I can tighten it without efing it up. If the line is broke, is this something I can get at an auto part store? I called advanced auto and they said they have it but it's generic and needs to be bent and cut. I think he was talking about the long hard line leading all the way to the engine bay and not the small hose in question. Clueless. Thanks for your input
MUST TURBO
Old 12-23-2012, 05:31 AM   #7
cmcpher
Addict
cmcpher's Avatar
If it doesn't feel like it is gonna budge a little then don't tighten it just as a FYI from making that mistake one time. You might end up in a situation that this part is a dealer part if you don't have a store that makes fuel lines in your area. Advance is thinking hard pipe and not the flexible hose section with hard ends on it at the fuel tank.
On the prowl
Old 12-23-2012, 06:01 AM   #8
Gadget@URD
Supporting Vendor
Tacoma: 2005 XRunner 422 RWHP
Those type fuel connections on Toyota tend to seize up and you can't get them apart or tighten them.
The fix is likely going to be to cut the hard line on each side of the junction with a tubing cutter. Debur it and the slide a length of high pressure hose over each end of the pipe and use two fuel line clamps on each side of the joint. Make sure you have the the two clamps on each end going in opposite directions.
We are looking at a 15 minute repair here.
G
Gadget@URD is offline   Reply With Quote
Old 12-23-2012, 07:24 PM   #9
2000blacktaco
Enthusiast
Thanks for your help FIXEDDDDDDDD I hacksawed it off on each side of the fittings and hosed it back in with double clamps on each side. Time to drank...
MUST TURBO
Old 12-25-2012, 03:49 PM   #10
nxrunner
StepSIde!!!
nxrunner's Avatar
Tacoma: 05 Xrunner (destroyed then traded`4 transmissons later)for a Rare 2000 1/2 XCab StepSide
G
I did exactly what is written here for a buddy of mine that ran a long screw into his fuel line while installing an amplifier in the extra cab behind the driver's seat. Fuel went everywhere even inside the truck. Simple but very effective fix. I used double clamps to ensure no leaks.
2"/3" Drop~Black Headlights,Bumper&Clears~Custom Intake~MonoMax All Around~Pioneer DVD Player~Rockford T1 12 in a Custom Box~Infinity 1600watt Amp~Kicker Tweets&Mids~Custom Shift Knob~Rhino Liner~ Konig Stampede Wheels
nxrunner is offline   Reply With Quote
Fuel lines ID N2BNLO Performance 5 05-08-2009 09:45 AM
fn fuel lines INTHABLOOD Performance 5 12-17-2008 11:17 AM
Confirmation on fuel lines BlackSportD Performance 12 06-19-2008 07:03 AM
Reinstalling fuel lines in 3rz Help Buff's Taco 1995.5 - 2004 7 03-19-2007 02:31 PM
Fuel lines??????need help fast nevertolow Exterior/Body 1 04-26-2004 07:30 PM
