Item LOC: 626, LA, CA
Price $80
PN: 22250-46030
Item Description: MK4 Supra Twin Turbo Mass Airflow Sensor
This MAF is a must have upgrade for supercharged 4Runners and some Tacomas. Or if your utilizing a 3.4 SWAP and your maf that is being utilized is the larger non drop in MAF found in the 99-2002's
f your truck or 4Runner is a 1998 or older. YES, Makes a HUGE difference. I am using one on my truck. Yes, I installed it along with fuel upgrades and a Apexi Super Air Flow Controller II. My truck pulls a lot harder especially in the higher RPMs where the smaller bottleneck air flow sensor is to restrictive to let the higher volume of air through. I would not suggest putting one on without the fuel upgrades. All you will do is make your truck run leaner than it already is running with all the stock parts with a TRD Supercharger. The following pictures show the obvious size difference between the Supra twin turbo AFS and the smaller 3.4 5VZ AFS.
Read all about it! Thread on the benefits of the MAF upgrade
http://www.yotatech.com/f2/supra-maf-s-cd-96-a-84874/
http://www.ultimateyota.com/smf/inde...ic=3901.0;wap2
http://www.customtacos.com/forum/sho...d.php?t=155671
http://www.customtacos.com/forum/showthread.php?t=37221
