Flywheel install question - CustomTacos.com Forum
Old 12-07-2012, 07:15 PM   #1
tacomatic1
tacomatic1's Avatar
Default Flywheel install question
I am installing a fidanza aluminum flywheel and in the direction it says to use oem torque specs..is this true?
if so what are they?
thx!
Old 12-07-2012, 07:27 PM   #2
mitzu
Grand Tacoholic
mitzu's Avatar
Tacoma: 03 S Runnerrrr
Default Re: Flywheel install question
ncttora.com
also, loctite them ****z
Stop being sexist.
Bitches hate that!
mitzu is offline   Reply With Quote
Old 12-07-2012, 08:48 PM   #3
toycoma98
toycoma98's Avatar
Tacoma: 1998 2-RZ Turbo @ 10 PSI. Original owner since 1997
You must get new flywheel bolts (10) They are one time use only. I ordered from local Toyota dealer.
http://www.lcengineering.com/LCInstr...structions.pdf
I have a Fidanza
toycoma98 is offline   Reply With Quote
Old 12-08-2012, 07:49 AM   #4
Enola Gaia
Enola Gaia's Avatar
The LCE torque specs (in the link above) don't match the FSM.
The listed torque spec (19 ft. lbs., then turn 90 degrees) is for a 3RZ only (according to the FSM).
For a 2RZ, the FSM lists the torque spec for the flywheel-to-crankshaft bolts as simply 65 ft. lbs.
Old 12-08-2012, 09:40 AM   #5
Speed Freek
Tacorvette enthusiast
Speed Freek's Avatar
I have reused them with no problems, and have done so probably 20 times (not all on the same one) Or upgrade to ARP if you want piece of mind.
Also use some RED loctite on them. And when tightening do so in a criss-cross pattern as well as the clutch pressure plate in small steps. Also use (i use blue) loc-tite on pressure plate bolts as well.
Also clean all mating surfaces of the clutch, flywheel and pressure plate with brake clean to get all the oil off them before install (probably already knew that).
BOOST BRIGADE I fabricate custom parts: HEIM STYLE STRUT RODS, FORWARD FACING INTAKE MANIFOLDS, and TRACTION BARS (5 LUG) contact me for more info @ www.Speed-freek.com or just PM me here THANKS!
Former Lexus / Toyota tech
Speed Freek is offline   Reply With Quote
Old 12-08-2012, 01:31 PM   #6
tacomatic1
tacomatic1's Avatar
too late now... haha
Old 12-09-2012, 08:29 AM   #7
toycoma98
toycoma98's Avatar
I think thats how 1 ARP bolt snapped back in 2006.
Brand new ^
Someone should clear this up. I cant find my Haynes book and i cant get to ALLDATA in school.
2012 ....
6 years later ^
I'm going with new stock bolts with red loctite this time.
Old 12-09-2012, 10:39 AM   #8
Enola Gaia
Enola Gaia's Avatar
Originally Posted by toycoma98 View Post
... Someone should clear this up. I cant find my Haynes book and i cant get to ALLDATA in school. ...
The figures I quoted are from the FSM. They're consistent from 1995.5 through 2004.
Old 12-09-2012, 01:57 PM   #9
tacomatic1
tacomatic1's Avatar
I called luis today and asked him. He said he torques the ARP bolts to 65 ft lbs like the oem bolts. Luis also mentioned that 65 ft lbs has never backed out on him. Keep in mind ARP bolts are NOT Torque to Yield bolts. They can be reused and because of this, the 19 + 90 spec is wrong for them, you will never see a TTY bolt with a degree added on to its spec.
Harder, stronger bolts (like ARP) will typically have higher torque ratings than other bolts with comparable threads. Torque ratings are also specified with a lube type.
The person I had helping me and I did 19 ft lbs + 90 degrees and we did not lube the bolts or use loctite (I have put 200 highway and street miles on it since). I am rather worried and am considering strongly to pull it ALL back apart...which makes me sick to my stomach. I do not have a huge jack and huge jackstands so I will have to buy all that.
Old 12-09-2012, 02:22 PM   #10
Chris D.
ADMlNAHATER
Chris D.'s Avatar
I just gun all of mine on in a star formation, I go by sound with my impact and I've never had a problem..
I wouldn't worry about it..
Clutch/Flywheel/Truetrac install this weekend! tylerangle1990 Performance 24 07-30-2009 02:41 PM
Flywheel and clutch install (pics) flatboy Performance 35 05-01-2007 09:17 PM
one more amp install question radtcma Interior/Audio/Electronics 6 03-17-2007 03:36 PM
last amp install question, hopefully radtcma Interior/Audio/Electronics 7 03-13-2007 03:03 PM
flywheel install toycoma98 Performance 10 08-16-2006 12:31 PM
