power windows - CustomTacos.com Forum
Old 12-05-2012, 10:55 PM   #1
garetcurry
garetcurry's Avatar
Tacoma: 2002 2wd Xtra Cab
Default power windows
Does anyone here have power windows that came stock with their 2001-2004 Tacoma? How far do your windows roll down? I did a swap a while back and my windows only roll down where there's about two inches remaining. Both the driver's side and passenger site stop at the same height, it boggles me and drives me be bonkers. I'm about to drop some coin to change back to manual regulators with universal actuators just so I can go all the way down. I need to replace the passenger side motor anyways, is done broke.
My Build
garetcurry is offline   Reply With Quote
Old 12-06-2012, 06:12 AM   #2
Enola Gaia
Enola Gaia's Avatar
Default Re: power windows
Sounds like something (control unit? regulator setting when installed? ...) is out of adjustment, so that "down to two inches" is considered "all the way down". I'm not sure what would cause that.
Old 12-06-2012, 09:11 AM   #3
Chris D.
ADMlNAHATER
Chris D.'s Avatar
Mine are factory and they roll all the way down..
They seem to be getting slower in their old age, any fsm action for maitenance Randy?
Tubro, bro!
Old 12-06-2012, 09:49 AM   #4
Enola Gaia
Enola Gaia's Avatar
I'm not aware of any prescribed maintenance. The motor units are sealed; they basically either work or they don't.
Old 12-06-2012, 10:24 AM   #5
garetcurry
garetcurry's Avatar
There's basically a gear that the motor tracks along and I'm running out of gear when my window gets to the bottom, but have some gear remaining when it's at the top. I need to somehow adjust that range, I've unscrewed the motor so I can adjust the gear, but it just reverts back... ugh, I'm prolly making no sense.
My Build
Old 12-06-2012, 02:16 PM   #6
Enola Gaia
Enola Gaia's Avatar
I understand what you're saying, and it makes sense as what you want to accomplish.
However, I can't find any FSM mention of adjusting the gearing / tracking on the power window mechanism ...
Where did your regulators / motors come from?
Old 12-06-2012, 03:22 PM   #7
garetcurry
garetcurry's Avatar
I bought SPROKIT's stock power window regulators, door panels, all wiring, controls, ect. and put them in my truck. Didn't he have an S-Runner? I had to run some wires here an there, but it's as close to stock as it can be.
I don't think there's a way to get her any lower, as the scissor maxes out at the bottom, thus the mechanism is the limiting factor here.
I normally wouldn't even bother fussing with this, but my passenger side went out. I figured while I'm messing with that, might as well cure this no-down-all-the-way issue. F*ck it, I'm going to buy some manual regulators and a universal power window kit. Shouldn't take me too long to do it.
My Build
Old 12-06-2012, 04:19 PM   #8
Chris D.
ADMlNAHATER
Chris D.'s Avatar
He also had a lowered 4x4 that I believe he gutted out..
And it mite not be a 01-04 body style if memory serves..
Tubro, bro!
Old 12-08-2012, 12:26 PM   #9
Speed Freek
Tacorvette enthusiast
Speed Freek's Avatar
Chris, use some Silicone spray where the window slides into the tracks (the rubber/felt ones that are exposed above door panel), thats usually where it sticks causing it to slow down, after you spray some lube on those things they will seem like they are supercharged!
It is rare that they stick in the lower section where the motor and drive slides are.
As far as the OP window issue, never seen that before, wierd.
BOOST BRIGADE I fabricate custom parts: HEIM STYLE STRUT RODS, FORWARD FACING INTAKE MANIFOLDS, and TRACTION BARS (5 LUG) contact me for more info @ www.Speed-freek.com or just PM me here THANKS!
Former Lexus / Toyota tech
Speed Freek is offline   Reply With Quote
Manual Windows-Locks to Power- Windows- Locks? BRTaco Interior/Audio/Electronics 5 04-27-2012 10:08 PM
A1 Power Windows and Power lock kits, JoeyT Interior/Audio/Electronics 9 12-05-2007 08:50 PM
anyone use factory power armrests w' A1 power windows? Bhavesh Interior/Audio/Electronics 0 08-18-2007 10:19 AM
Power Windows Xacto 1995.5 - 2004 2 05-21-2006 08:47 PM
adding more Power to the "power windows"?? DeA7hWiSh Interior/Audio/Electronics 32 04-28-2004 02:15 PM
