Boost line - CustomTacos.com Forum
Old 11-15-2012, 12:20 PM   #1
Yodaforce
Grand Tacoholic
Yodaforce's Avatar
Tacoma: 2001 S-Runner boosted with alot of URD parts.
Default Boost line
Any recommendations on a better way to pipe the boost line, particularly to the gauge?
The crappy "weed wacker" line has failed me twice now and getting it to seal is not working out.
Diverse-Customs.com
Yodaforce is offline   Reply With Quote
Old 11-15-2012, 12:43 PM   #2
Josh Taco
Josh Taco's Avatar
Tacoma: 1999 toyota tacoma
Default Re: Boost line
Silicone hose is the way to go. I tapped the brake booster to a vacuum block and go from there...
Old 11-15-2012, 01:04 PM   #3
tacomatic1
tacomatic1's Avatar
does your boost gauge use a compression fitting? I am using one with the tiny 3/32 nylon tubing and it works well.
Old 11-15-2012, 02:51 PM   #4
Yodaforce
Grand Tacoholic
Yodaforce's Avatar
Yeah, looks like a standard 1/8th inch brass compression.
Diverse-Customs.com
Old 11-17-2012, 12:53 PM   #5
Yodaforce
Grand Tacoholic
Yodaforce's Avatar
I am going to try to find a female barbed fitting today. I now have some silicone line.
Diverse-Customs.com
Old 11-18-2012, 01:13 PM   #6
Chris D.
ADMlNAHATER
Chris D.'s Avatar
The secret to the weed wacker line is finger tight + 1/4 turn, leave slack for engine movement.
Tubro, bro!
Vacuum line for Manual boost controller 671taco Performance 21 05-07-2010 08:11 PM
Line level/Line out converter help (2006: Wiring?) djcreeper Interior/Audio/Electronics 4 12-04-2007 01:10 PM
Boost line connections to supercharger cheez Performance 3 01-07-2006 05:13 PM
Boost line question RzrBlade Performance 3 08-25-2004 06:34 AM
What line to tap into for boost gauge? TacoNightRider Performance 13 11-14-2002 10:59 AM
