Re: Need a new clutch. Which should i get?
i had a similar problem a few months ago. 175k everything oem,the master and slave seemed to work fine.i replaced the clutch,flywheel,and bearings that had no visible wear. same problem remained. flushed/bleed the fluid and it was good as new. i recommend trying that first, i have heard that centerforce clutches have had pressure plate issues after a short time. if you do get a new clutch id choose paradise
13% of homeless in the USA are veterans
